big engine small filter
I had the G up on a lift today and was very surprized how small the oil pan was and especially the oil filter. You could say the filter looks kinda squarish and around the length of your index finger. Thats pretty much the smallest car filter I ever saw. Granted it allows higher psi, the filtration is very questionable.
I'm assuming Nissan knows what they're doing...
C.
On my 2005, it used a small filter, maybe the same. I used a larger filter when I changed the oil... the same one for the pathfinder and such, which I believe (interestingly) is also used on the 5.6 engines...
ENVautoDetailing.com
All nissans 2000 and up use that same small filter, even the 5.6 endurance V8 in the Titan...
... I'm sure nissan knows what they're doing if these cars are lasting well over 150k
-GP-
... I'm sure nissan knows what they're doing if these cars are lasting well over 150k-GP-
