gas pump issues
Old Feb 28, 2007 | 09:09 PM
DIGItonium's Avatar
Samething happens on my Z since I first got it, and they even replaced the valve a couple of times. What you do is gently squeeze the handle so fuel flows slower and it works everytime. After that fully squeeze it for maximum flow. If it cuts off again, do the same thing.
Old Feb 28, 2007 | 09:51 PM
SPEEED's Avatar
Bad Toro
Oh boy. I hope it's not a rerun of the TSB they had for the 03-04 models.
Old Feb 28, 2007 | 09:57 PM
detracti's Avatar
I had that happen the other day. Just ended up going to another gas station, where it filled up.
Thanks for the tip.
Old Feb 28, 2007 | 10:41 PM
Cost a G's Avatar
What kind of gas station are you going to? If its shell then that could be your problem because I can never get a full tank at any shell gas station, it would fill half way and stops. Exxon/mobile, Chevron all works fine though.
Old Feb 28, 2007 | 11:23 PM
Christian's Avatar
I usually gas up at Shell and I haven't had any issues.
Old Mar 1, 2007 | 12:44 AM
detracti's Avatar
Chevron is where I had the problem. I just drove next door, I think it was a Texaco, and filled up there. It must be either the equipment itself, or how it is set up.
Old Mar 1, 2007 | 12:52 AM
MoCoG's Avatar
Originally Posted by mobileg35
this may seem like a total noob question, but I've had this issue twice on the two occasions I have had to gas up my new G.
At any gas station these days they have the _auto stop_ feature right, you sort of hook the gas lever so it continues to push gas, while you can stroll around the look at your car... and then when the tank is full it automatically clicks off... know what I am talking about?
Well, first time, I had a pump that would make the click sound and stop when the tank was half full. at which point I had to manually keep pressing the gas lever - and it would click off even then after pumping in a little more gas - sort of like what the pump should do when the tank is already full.
I know its half full because I only put in say 8-9 gallons. and this same thing happened today again when it stopped at 8-9 gallons at the pump. and did the same auto click/stop even when i tried it manually.
anyone else notice this, how should I be pumping gas...?
its all 91 Octane FYI.
thanks
mobileg35
I've had this happen in NJ, where we have the same vapor collection system that California has. I simply insert the nozzle upside down so the lever is above the nozzle instead of below. This changes the angle the fuel enters the pipe, presumably reducing backsplash. I've never had a problem doing it that way.
Old Jun 11, 2007 | 11:51 PM
VtecVQ's Avatar
I just had this problem! I will have to try the upside down technique. I tried filling up at two Shell's, then one Chevron, and still had the same problem. I finally just pumped manually with a slow pressure and it filled up.
Old Jun 12, 2007 | 12:50 AM
hyukki's Avatar
I've filled up about 8 times already (I barely hit my 1 week mark. Well, a week and 2 days.) and I don't seem to have this problem. I do the back off thing almost everytime because that's how I learned... I'm not having any problems yet but I'm a bit worried now since a couple of you guys are experiencing things.
Old Jun 12, 2007 | 01:46 AM
MojoKidd's Avatar
No problem here, my G loves gas, it seems to drink it by the gallons. She gets nothing but the best 93O. It's a good thing I work in the energy industry.
Old Jun 12, 2007 | 01:48 AM
hyukki's Avatar
I would like to put 93 but I can only get 91. CA sucks.
Old Jun 12, 2007 | 01:53 AM
BayAreaRefuGz's Avatar
i fly low
that happened to me couple times. i learned to readjust the nozzle. if it doesnt lock up, then it's the nozzle itself.
Old Jun 12, 2007 | 11:46 AM
tkbr0wn's Avatar
This happens to me as well, I will have to start checking the fuel pump brand to see if it is specific to that. The brand is usually on the pump visible (Gilbarco, etc...)
Old Jun 12, 2007 | 12:13 PM
Altersys's Avatar
the tip of the nozzle must be resting in a locked position against the top of the filling tube, as described above.
i think your filling technique just needs some refinement. how many times has this happened so far? different pumps each time?
Old Jun 12, 2007 | 12:20 PM
  #30
spacecowboy's Avatar
as someone who lives in jersey where we dont pump our own gas, i've never had any problem with putting gas in. Not a single attendant has ever had any trouble, nor has anything ever happened.
I think it's you guys.
