Found source of rear deck rattle/buzz
Originally Posted by csdstudio
I found the source. It's the selt belt mechanisms, just under the rear deck. They tried to cover up the buzz a little by putting little black boxes under the deck that cover the retractor systems. Must be all the springs and guts inside the tensioners. If you tap on the rear deck, you can here the faint rattle/buzz. Not sure that can be fixed. Any ideas?
Anybody figure it out?
"I had the same problem. Took it to the dealer and they said it was a loose screw. I'm not sure which one but it was either a screw on the amp or a seatbelt screw. I recommend taking it in and have the dealer figure it out"
Was the problem resolved? Anyone else have this problem I am now at 17K and it has been driving me nuts, I think i am going to try and fix it myself this weekend, now that the weather is a little more mild.
I've spent the last couple weeks sound deadening my car and you wouldn't believe what a difference it makes. First off, my car hasn't had many random rattles but when playing loud music (especially with a lot of bass), the door panels and sub grills would rattle significantly. Just the process of going through and applying some RAAMmat has made almost all of those rattles go away.
I would suggest that if you have a specific rattle, buy a small Dynamat (or similar) kit and apply some of the material to that area. I'd bet it solves the issue for you. If you have more rattles, consider doing the whole car. I choose RAAMmat because it comes in 62.5 sqft rolls and I'm hitting almost everything. I think it's a great investment.
rezendvous420
05-31-2020 01:26 PM
bu villain
19 Inch
11-15-2015 09:23 PM
