Technical Bulletins before taking delivery
Old Mar 13, 2007 | 03:53 PM
G35-2-B's Avatar
I pick up my car in 10 days. Should I expect the outstanding Technical Bullentins to all be done....or should I expect the opposite, ie they would not be done until I take possession and actually complain about the issue the TB is intended to fix?
TB's : http://www.infinitihelp.com/Bulletins/G35/2007/1.htm
Old Mar 13, 2007 | 04:00 PM
Garnet Canuck's Avatar
Traveling Administrator
I'd ask your dealership that question.
Old Mar 13, 2007 | 04:01 PM
G-Whizzer's Avatar
If it isn't broken - don't fix it...
I have none of the problems mentioned in the TBs - and would be concerned that having someone fix it if it's OK might lead to something else going wrong.
Old Mar 13, 2007 | 04:09 PM
hokiesean24's Avatar
You could suggest that they check these items out prior to pick-up... and arrange to fix them if there are any issues.
Old Mar 13, 2007 | 04:23 PM
Christian's Avatar
The only TSB issue I've noticed so far is the rubber finisher on the sunroof popped off yesterday, but it clipped back on easily so I'm not concerned at all.
Old Mar 13, 2007 | 04:38 PM
XXeR's Avatar
i actually asked my salesman about the TSB on the rear window before i took delivery. he went and asked the service mgr, and he said there is no reason to start wrenching on the car when it may not even have the problem.
yes, it could have simply been laziness, but it was a good point regardless.
Old Mar 13, 2007 | 04:57 PM
CarFreak's Avatar
I haven't noticed anything except for the heated seats issue. I'm going to wait till a have a good list before I drop it off at the dealer. I rather not have the dealership play around with minor issues and make them major
EasySausage
Sep 24, 2015 01:06 PM
ChrisAult2004
Sep 11, 2015 10:33 PM
junon
Sep 5, 2015 10:40 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
Detailed Image
Sep 4, 2015 08:35 AM
