Cruise Control Lockout When Wipers On??
Old Mar 22, 2007 | 08:50 AM
UltimateGee27's Avatar
Originally Posted by SPEEED
It's by design. The car knows not allow you to engage the cruise control in rainy conditions for safety reasons.
actually if you turn off the wipers for a second and engage the cruise control..and then turn the wipers back on it still works??? so i guess they give you a loop hole to work with in the system NEO
Old Mar 22, 2007 | 09:13 AM
randman's Avatar
The ICC can't be used when the wipers are in the LO or HIGH positions. It's not clear if cruise control w/o ICC also won't work with the wipers in the LO or HIGH positions. But, I believe ICC and non-ICC cruise control works if the wipers are in the intermittent position. So, drive slowly and use intermittent while eating your Big Mac!
FYI: http://www.snopes.com/autos/techno/wetroad.asp#icbc
Old Mar 22, 2007 | 09:23 AM
kring's Avatar
I can confirm that the ICC version works when the wipers are set to intermittent. And if you use Aquapel, you don't even need wipers!
Old Mar 22, 2007 | 09:33 AM
Just another cool safety feature Inifniti provides us without having to advertise it all crazy...
Imagine that...
Introducing the all new 2007 Infiniti Gee with Cruise Control lockout when it is raining and the wipers are on. lol
Old Mar 22, 2007 | 07:56 PM
Adam Zapple's Avatar
The ICC struggles in heavy rain, so when you put the wipers on full it will turn off the cruise control. You can have the wipers on intermittant with ICC activated. A little rain will not confuse the sensor.
If you want to use cruise control in the rain with your wipers on full, you hold down the cruise control button for three seconds and it disables the ICC and allows you to use normal cruise control. All of which is documented in the manual - you know, that thing you have in the car somewhere :P
In heavy snow, the ICC sensor at the front will get covered. The car will then disable the ICC and issue a warning that the sensor is blocked.
It seems to behave as I would expect it to.
Old Mar 27, 2007 | 03:05 PM
wongsooiseng's Avatar
What is an ICC?
Sooiseng <-- Silly question
Old Mar 27, 2007 | 03:07 PM
Intelligent Cruise Control
Old Mar 27, 2007 | 06:47 PM
is not on 05 g35 coupe 6mt right?
Sooiseng
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
markbilo
Sep 30, 2015 01:33 AM
