Service Light.
Old Apr 6, 2007 | 09:37 AM
BKblack's Avatar
Service Light.
Ok ... so I've had my g35x for about two days now and am loving it .... Untill this morning when I notice the "engine service soon" light come on. Ive got about 95 miles on the car !
Theres no way this is normal, right ? Ive got to call service now....
Old Apr 6, 2007 | 09:50 AM
hokiesean24's Avatar
Yeah, I would def call them immediately. It could be anything, maybe fluid levels or something from dealer prep WHO KNOWS-
Old Apr 6, 2007 | 10:46 AM
^^ much better than my advice!!!
Good work Treacherous!
Old Apr 6, 2007 | 10:55 AM
BKblack's Avatar
Thanks ill give that a try in the parking lot ... but where am I looking for this code ? on the nav screen ?
Service(Kings Infiniti in Brooklyn) Says its nothing major, maybe form fueling the car with the engine on and to Just to keep driving and come in on Monday
Old Apr 6, 2007 | 12:14 PM
gway84's Avatar
my service engine light came on the other day so i took it in. turns out it was some kind of sensor that was activated because my gas cap was not as tight as it should be. make sure to turn it till it clicks and that it is in straight.
Old Apr 6, 2007 | 12:18 PM
max2k1's Avatar
Originally Posted by treacherous
Here is how to pull a code.
Pulling CEL codes:
HOW TO SET DIAGNOSTIC TEST MODE II (SELF-DIAGNOSTIC RESULTS)
1. Confirm that accelerator pedal is fully released, turn ignition switch ON and wait 3 seconds.
2. Repeat the following procedure quickly five times within 5 seconds.
- Fully depress the accelerator pedal.
- Fully release the accelerator pedal.
3. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 10 seconds until the MIL starts
blinking.
NOTE:
Do not release the accelerator pedal for 10 seconds if MIL may start blinking on the halfway of this
10 seconds. This blinking is displaying SRT status and is continued for another 10 seconds.
4. Fully release the accelerator pedal.
ECM has entered to Diagnostic Test Mode II (Self-diagnostic results).
If I'm online I'll check in Service manual on what you find for codes.
Would it be the same code that I can get using an OBD II scanner ??
That maybe an easier way to get the same thing (if you have a scanner) !!
Old Apr 6, 2007 | 12:42 PM
whtbst's Avatar
$100 says it's the gas cap. It happened to me three days after driving away from the dealership after my purchase. I took it into the dealer because obviously I freaked out that the light came on, and sure enough it was the gas cap. If you want to avoid going back to the dealer (i.e. wasting 3hrs of your day), then my dealer told me to twist the cap until you hear at least 4-5 clicks, then after 5-6 starts (separate driving sessions), the engine light should turn off thereafter.
Old Apr 6, 2007 | 08:42 PM
oneformula's Avatar
gas cap
Old Apr 8, 2007 | 04:35 PM
BKblack's Avatar
Yea looks like I owe someone $100 .... sure was the gas cap, after I checked it the light went off within 20 mins. Sure was a scare though.
Thx. Everyone
Old Apr 8, 2007 | 09:23 PM
whtbst's Avatar
told ya
Old Apr 8, 2007 | 11:36 PM
Jason@Riverside's Avatar
the fuel filler cap may have not been installed correctly after they filled up the tank for delivery...
ive seen this soooo many times...
06g35
Feb 14, 2022 05:59 AM
Diode Dynamics
Accessories-Vendor
39
Nov 30, 2021 02:28 PM
f22raptor
Mar 18, 2016 08:50 AM
heynow
2nd Gen (V36) Sedan
Oct 28, 2015 05:09 PM
