Sorting songs on CF cards
Old Apr 9, 2007 | 06:18 PM
SPEEED's Avatar
Bad Toro
I tried searching it but came up empty handed...
I took the CF cards out of the car so I can sort the songs the way they are listed on the original CDs. I thought that by putting double digits (01 song name1; 02 song name2; 03 song name3; etc. ....) in front of the songs, it would work. To my surprise, when I went back to the car and popped the CF card into the slot, the songs appeared in a random order (neither by numbers nor alphabetically as they originally were).
The interesting thing to note though was that when I copied a new folder containing songs with numbers in front of the song names it worked, but when I tried to sort existing folders it displayed the songs randomly
I guess the only option would be to wipe everything off the card, format it, and then re-copy everything from scratch...
Anyone knows anything about this?
Old Apr 9, 2007 | 07:39 PM
G-Whizzer's Avatar
I just checked and yup. It resorts them.
No real reason - I looked at size/name/date modified. No correlation.
The folders seem to be in the right order. But that's about it.
Maybe it's the way the data is embedded on the mp3. The musicbox reads the title names differently than my PC. Might be sorting by name??
Just a guess...
Old Apr 9, 2007 | 08:16 PM
RED_G35S's Avatar
i think the most recent songs you add to the cf card will be shown in the bottom of the list
Old Apr 9, 2007 | 08:36 PM
Garnet Canuck's Avatar
Traveling Administrator
Yeah, IIRC that is correct.
Btw, get your butt into the Picture Share section and post up some pictures of your G in the Garnet Ember thread.........I'm the only that has posted so far.
Old Apr 9, 2007 | 08:48 PM
G-Whizzer's Avatar
I added songs all at once and the order doesn't match the burn order on the PC list....
BTW, the PC didn't recognize 2 titles and the musicbox did.
Odd.
Old Apr 10, 2007 | 07:17 AM
dcmidnight's Avatar
Odd and very annoying. Again I will reiterate that Infiniti really, REALLY needs to update the CF/MB software. If its truly hard drive based, this shouldn't be a huge deal to get everyone.
Old Apr 10, 2007 | 11:13 AM
SPEEED's Avatar
Bad Toro
I will try to format the card and re-copy everything back to it to see if that will correct the problem.
Old Apr 10, 2007 | 11:29 AM
Christian's Avatar
Editing the meta data to correct the ordering of the songs on the CF card was discussed in another thread from January. Does anyone know if this works? What program are you using to edit this data?
https://g35driver.com/forums/showthr...hlight=CF+Card
Old Apr 10, 2007 | 12:15 PM
GumboChief's Avatar
Do CD-Rs have the same sorting issues?
If not, I will just use those.
Old Apr 10, 2007 | 06:51 PM
hullio's Avatar
Just on a random note, can you watch videos and or pics from the CF card while in park?
Old Apr 10, 2007 | 09:13 PM
SPEEED's Avatar
Bad Toro
To the best of my knowledge the answer is no. The CF reader will only recognize sound files (I had a bmp file accidentally dropped in one of the folders and it didn't even list it).
You can however, hook up an iPOD or portable DVD player to the Aux ports located in the arm rest to achieve that.
Old Apr 10, 2007 | 10:59 PM
hullio's Avatar
Thank you sir Another quick question, would the old gen. iPods play? I have the 4th gen. 20GB iPod and the last gen. iPod Nano 4GB.
Old Apr 10, 2007 | 11:58 PM
terrycs's Avatar
The AUX port in the car reads RCA inputs - with or without video feed.
Old Apr 11, 2007 | 12:08 AM
yidster's Avatar
Angry You have to add the files one at a time
I was able to get the proper order on my CF card.
Unfortunately, I had to copy the tracks one at a time. It seems the CF card will display tracks in the order they are copied onto it. So when I copy and pasted 12 tracks, it would put them on the CF card in whatever order it saw fit and that is the order you would see it in the car.
To circumvent this problem, I cut and pasted one track at a time into each folder and that did the trick...
What a PITA!
He2
Old Apr 12, 2007 | 10:49 AM
SPEEED's Avatar
Bad Toro
NICE!
It worked! For anyone who wants to sort his songs in a certain order (as opposed to playing them alphabetically), just drop 2-digits in front of the song name (on the PC), format the card, and re-copy everything back onto the card.
Patrick Bovee
Oct 1, 2015 10:42 AM
1Typhoon
Sep 25, 2015 08:45 PM
