Preview Braking..I'm Confused..
Old Apr 13, 2007 | 08:46 PM
hullio's Avatar
Well I looked in the manual, but I still don't fully get how this feature actually works. Does a little screen pop-up in the screen between the spedometer telling to you to brake when the car infront of you is too close to the G? So how does this whole "Preview Braking" thing work? It's always on anyways isn't it? The button on the steering wheel (on the right side) underneath ON/OFF button for cruise control is the car with the three bars under it (or something like that, can't remeber fully)...that's the ICC button to control the distance for the laser beam correct? Is that only for curise control or for also the preview braking? Thanks
Old Apr 14, 2007 | 08:01 AM
kring's Avatar
Preview braking has two different features, the first that is "always on" is the brake charging. Basically when you are approaching something fast or you are very close to a vehicle in front of you, the system will charge up the brake system in anticipation of you needing to use the brakes quickly. I've felt this before, it turns the brake pedal really hard and the slightest press on the brakes is amplified. I thought I remember reading somewhere that preview braking also alerts some of the other safety systems that you may need to make an emergency stop or evasive maneuver.
The second part of preview braking only works when the ICC is enabled and set. It give out an audible alert when you are approaching something at a high rate of speed. The system is alerting you that in order to properly stop the driver may need to intervene since the ICC can only apply 25% brake-force. If the ICC ever starts beeping and flashing on the screen, that's when it's kicked in, if that happens, put your foot on the brake and you will feel how hard it is.
PaKmaN
Feb 14, 2006 12:09 AM
JDM_CPV35
Jul 9, 2005 06:47 AM
Gee Im Fast
May 3, 2005 05:28 PM
