When To Charge Keyfob?
Old Apr 20, 2007 | 02:23 PM
ramo's Avatar
I was wondering how often you are supposed to put your keyfob into that cradle next t othe steering wheel?
Old Apr 20, 2007 | 02:34 PM
max2k1's Avatar
That "cradle" does NOT recharge it.
It is only to be used when your fob is out of battery.
you just replace it with a new battery when that happens (see ur manual 8-24)
terrycs's Avatar
It's not a charger ... it's only used for "emergencies" when the ikey baterry dies.
Old Apr 20, 2007 | 04:43 PM
IsaG35's Avatar
I just looked this up in manual last night the battery is CR2032
Might be good to keep some extra batteries on hand.
Old Apr 20, 2007 | 06:21 PM
terrycs's Avatar
Did it say how many?
Old Apr 20, 2007 | 06:33 PM
CalsonicVQ's Avatar
Please don't say your dealer told you it was a keyfob charger.
Old Apr 20, 2007 | 11:46 PM
herschelg123's Avatar
My dealer told me, and I quote, "This spot right here is the charger for your fob. You stick it in and it charges the battery. You will need to do this every 3 years or so."
I am not joking. Of course, anyone can look at the fob and see that there is nothing to make a connection in order for it to charge, unless the Infiniti symbol itself is the thing that causes it to charge.
Was the dealer full of sh-t? Probably. But I was skeptical, and I figured that if anything in the fob did start to go bad, I would have asked about the battery when the time came.
Old Apr 21, 2007 | 12:32 AM
oneformula's Avatar
my braun tooth brush charges without metal contacts. my bmw charged the key everytime it was in the ignition using the same method.
that said, our fobs do NOT charge in the fob slot.
Old Apr 21, 2007 | 06:50 AM
calibur45's Avatar
my dealer told me to charge it in the fob once every month.. ok... :\
Old Apr 21, 2007 | 11:11 AM
logik05se's Avatar
That slot is NOT a charger. However that slow will prevent the battery from draining anymore than it already is. Basicly it just holds the current charge that its on. Unfortunatly that is not very usefull because its not like the keyfob is in use constantly while the car is running that it needs to hold the current charge.
Old Apr 21, 2007 | 06:38 PM
G35MD's Avatar
Cheap CR2032 Batteries on Ebay
Cheap CR2032 batteries on Ebay can be found HERE.
Old Apr 21, 2007 | 10:58 PM
DaCurryman's Avatar
Are the batteries user-replaceable or do you need to get a new key. Kinda like how batteries in an ipod arent user replaceable.
Old Apr 22, 2007 | 12:54 AM
d12a60n's Avatar
The batteries are user-replaceable. You just need a small flat head. Read the user manual. It's in section 8 pages 23-24.
Old Apr 22, 2007 | 01:14 AM
oneformula's Avatar
i've replaced batteries in iPods. quite easy, really.
Old Apr 22, 2007 | 03:15 AM
DaCurryman's Avatar
good to know...thanx.
