VLSD fails after 60,000 miles?
Old Apr 29, 2007 | 08:10 PM
cup0spam's Avatar
Taken from Wikipedia:
Viscous LSDs are less efficient than mechanical types, that is, they "lose" some power. They do not stand up well to abuse, particularly any sustained load which overheats the silicone results in sudden permanent loss of the LSD effect.[4] They do have the virtue of failing gracefully, reverting to semi-open differential behavior, without the graunching of metal particles / fragmented clutches. Typically a visco-differential that has covered 60,000 miles or more will be functioning largely as an open differential; this is a known weakness of the original Eunos Roadster sports car. The silicone oil is factory sealed in a separate chamber from the gear oil surrounding the rest of the differential. This is not serviceable and when the diff's behaviour deteriorates, the VLSD centre is replaced.
I'm not sure if this is applicable to the VLSD offered on the sport sedans, but are they really practically useless after 60,000 miles or so? Is this considered normal wear an tear? How would one prove this to the dealer?
Old Apr 29, 2007 | 08:23 PM
G-Whizzer's Avatar
"this is a known weakness of the original Eunos Roadster sports car."
Not sure that this applies to more modern LSDs...
Old Apr 30, 2007 | 09:05 AM
SPEEED's Avatar
Bad Toro
Not sure Wikipedia applies to anything....
Take whatever you read on that site with a big chunk of salt...
Old Apr 30, 2007 | 11:06 AM
max2k1's Avatar
^^ +1 on the trust worthiness of Wikipedia .... a lot of "opinionated" posts are out there
linedr89
Aug 17, 2015 05:11 PM
myGspot
Drivetrain
Aug 11, 2015 11:58 AM
chinee
Aug 8, 2015 10:11 AM
whattf
Drivetrain
Jul 20, 2015 11:19 AM
