Remote Start on G35
Originally Posted by da mayor
the M's do it too... it's a safety mechanism so no one can steal the car from you
the only reason you need a key in the car is cuz of the chip. your car won't start if there is no chip within range...
and the brake thing is a security mechanism. that way no one can just get into ur car and drive off.
Originally Posted by coolie
I got remote start installed on my G35x from the dealer. Two clicks of the lock button and it starts. Hop in the car, push the ignition button twice and then the brake pedal and you're all set.
Shaun
Shaun
Originally Posted by johnmax
Yes we now have the modules to do remote start this way. No more of the car shutting down when you open the door....If it doesnt sense a valid I-key, then it will shut down when you hit the brake.
Sorry for the late reply.
My car never shuts off. I hit the lock button twice to start the car; the security stays armed. I keep the key in my pocket (like normal), walk up to the door and unlock it with the door handle button. I sit in the car, close the door and push the ignition button twice. After that, I step on the brake and it's good to go.
The security stays on and the car never dies. I made sure of that before I had them install it.
I don't have a cost, because I negotiated it into the cost of my car when purchasing it.
Edit: The only complaint I have is the range of the signal when remote starting. Otherwise I prefer having it installed from the dealer as opposed to an aftermarket system.
Shaun
Shaun
For you guys with the remote start option added, you might want to try this little hack out on your FOB, says you can get approx 50 ft more range with this little trick..
http://www.metacafe.com/watch/358044/boost_your_car_remote_range/
I plan on trying it out soon, but if anyone beats me to it, let me know how it works out.
Also, I wanted to confirm that when I remote start my car with the factory remote-start, what all turns on in the car.. does the AC, radio, headlights turn on when remote started?
Thanks.
Thanks.
Shaun
Shaun
Just FYI.
You do know that you are just overpaying for an aftermarket system that is installed at the dealer. All they do is bring in a guy like me. I charge them $300 and they charge you $800 or whatever.
Just FYI.
Just FYI.
Shaun
laksjd84
Jul 24, 2015 05:12 PM
