Aftermarket Sirius - Antenna Placement?
Old May 16, 2007 | 09:01 AM
mikelawr's Avatar
I was wondering if the satellite signal is strong enough if the antenna is placed in the car on the rear deck as close to the back window as possible. I'd rather put it there then on the roof if the reception is just as good.
Thanks,
Mike
Old May 16, 2007 | 09:29 AM
El Diablo's Avatar
Your reception won't be good enough in my opinion. If it were XM you would be just fine but Sirius will be a big pain in your *** if you put it there. You will lose signal if a bird flies over your car...not really but you know what I'm trying to say.
Old May 16, 2007 | 10:03 AM
Bigd2k6's Avatar
mine is on the rear deck wedged all the way where the glass and the deck meet (towards the trunk). that way it has as much view of the sky as possible and my reception is great.
Old May 16, 2007 | 12:01 PM
gspotter's Avatar
I have a Sirius antenna mounted on the inside of the front windshield just to the right of the mirror (inside the tint strip as well)- totally invisible from outside the car, and you don't even know it's there when inside the car- reception is great.
Old May 17, 2007 | 08:37 AM
mikelawr's Avatar
GSpotter... What did you use to stick the antenna to the windshield? Does it come with some kind of adhesive? Will it leave a mark when removed (I will be leasing the car).
Thanks,
Mike
Old May 17, 2007 | 03:29 PM
CodingDane's Avatar
I've got my Sirius Starmate in the car for now, until I get the Sirius factory unit and yank out the XM. I have the antenna on the rear deck, and it works fine, reception is always 2 or 3 bars.
Only problem is that sometimes during "spirited driving" (as they say), the antenna does flip over on its side and you lose reception. If it wasn't just a temporary install, I could probably velcro it down or something.
Old May 17, 2007 | 04:49 PM
Blaxima's Avatar
I have mine wedged between the windshield and dash...right in the center. Reception is fine, if not perfect!
Old May 21, 2007 | 04:03 PM
CaptG35's Avatar
In my last car i put the antenna in the rear window. It will have the same quality of signal, but it loses the signal much more easily. I lose signal whenever I drove on a road that is pretty overgrown on the side with trees.
jeffbdye
Jun 1, 2018 03:51 PM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
DEMoLITIoN
Apr 20, 2016 06:57 PM
Learned Hand
Oct 1, 2015 09:02 AM
