View Poll Results: Does your manual transmission clunk, crunch, or grind while shifting?
Yes
20
44.44%
No
25
55.56%
Voters: 45. You may not vote on this poll
Tally of how many people have problems with their manual transmissions
Old May 20, 2007 | 01:48 PM
CFar's Avatar
This post is really just to get a bearing on one specific issue; clunking or crunching manual transmissions. Please don't add any other problems that you may have. This post is really just a gauge to see how common this syncronizer problem is that causes a clunk, or crunch when shifting.
With that said, I'm on transmission number two and it is doing the same thing as the original, that is second gear clunks until it is thouroughly warmed up. Sometimes, it manages to crunch/grind into gear. All of the other gears work as promised, in the sense that they have smooth and quiet engagement.
If you have a manual, just vote!
Thanks,
Chris
Old May 20, 2007 | 02:32 PM
joeldoss's Avatar
My 6-speed is a little notchy going from 1st to 2nd. All other gears are fine. Once its warmed up, it's much smoother. I'm considering changing the gear oil. Joel
Old May 20, 2007 | 02:44 PM
J. Diddy's Avatar
I have problems with the rain coming off of my trunk and getting everything wet when I open it.
Old May 20, 2007 | 02:54 PM
G-Whizzer's Avatar
LOL> Obviously a RULE BREAKER! Or you don't ReAd 2 GoOd...
Isn't this about the MT?
Old May 20, 2007 | 03:38 PM
808MIKE's Avatar
Same here! A little Notchy on the 1-2 shift. but other than that all is smooth shifting with the other gear's!
Old May 20, 2007 | 05:06 PM
GoofyG28's Avatar
Has anyone changed their tranny oil? I wouldn't mind switching to Redline. I did it for my Mazda6, and BOY was it nice. And it helps to keep the tranny lasting a long, long time, too. That's probably the only engine-related mod I'll do to my beautiful-even-at-stock G.
Old May 20, 2007 | 05:13 PM
CFar's Avatar
I would, but don't want Infiniti to be able to point to something that I did and say that is what caused it. That would be an uphill battle in court if it came down to that.
tiguy99
Mar 1, 2016 11:42 AM
derres
Aug 28, 2015 03:27 PM
saskicker32
Aug 11, 2015 02:12 PM
multimut
Canada
Jul 26, 2015 08:43 PM
nervseele
Jul 17, 2015 11:21 PM
