OEM Oil Filter
Originally Posted by Craptastic
How much do those run? Do they have the special resevoir so all the oil doesn't drain out when you turn the car off?
Originally Posted by max2k1
^^^ Yes correct -- the anti-drainback valve prevents dirty oil from flowing "back" - this is in effect when the car is running or not. Also most filters have a by-pass valve.
dirty oil is better than no oil
The "by-pass valve" is what I was referring to. The mechanic I talked to called it a resevoir because it functions as a holding space (i.e. resevoir) for oil within the filter so there is always oil immediately available when you start the engine. Because as max2k1 states: Obviously I'm not referring to the oil pan, but it looks like you figured that out in your following post, Altersys. What I'm still wondering is if the oem filters have a "by-pass valve", since pretty much all filters have an anti-drainback valve (except for the really, really cheap ones). Also, if Infiniti recommends only using the Nissan filters, is there really that much to gain by using anything else? Thanks again for all your input everyone.
Originally Posted by ez-g
OEM Oil Filter - 15208-65F00
Originally Posted by Karman
Gm - PF1237, Fram - 6607, Wix - 51365, Bosch - 3300 are replacement filters. Cheaper than OEM. OEM # is in back of owners manual. I ordered one on line from MYNismo.com along with drain plug washer.
Originally Posted by SwivelMan
Fram is crap. Wix FTW. Or Amsoil filter if you really wanna treat your baby right (more $$).
Originally Posted by Virus
I'll dig up his number and post as well. Dave B's prices are the absolute best and his shipping and customer service are top notch.
Originally Posted by stardust
Dave Burnette's number is 888-254-6060
