G is pulling right...?
I noticed yesterday that the G is starting to pull slightly to the right. After noticing it, tried checking the tire pressure (they were within a pound, but equalized everything), and started checking road level (i.e. crown), wind effect. Long story short, it's pulling and the wheel is slightly left to compensate.
On a Sport I can't rotate the wheels; spoke to the dealer and they said an alignment MAY be covered by Infiniti (plus they are a 45 minutes away). Thoughts? Anyone else with a Sport experiencing this, with hopefully a fix?
[QUOTE=G35Now!]I noticed yesterday that the G is starting to pull slightly to the right. After noticing it, tried checking the tire pressure (they were within a pound, but equalized everything), and started checking road level (i.e. crown), wind effect. Long story short, it's pulling and the wheel is slightly left to compensate.
[QUOTE]
I hope this will be of some help. Although I have an 04 Coupe, I have had the exact same issue from new. I've had a TSB for a compression rod done (to compensate for caster adjustment). I've had numerous alignments and everything is within spec. My steering wheel also points slightly to the left on all highway services. The only time my wheel will be exactly centered is if I'm on the left side of the road and the grade is slanting to the left. I believe these cars are very sensitive to road irregularities and my car will drift to the right as well at higher speeds. I'm apt to believe this is normal. Try a demonstrator or loaner and make a comparison. Most of these cars have this characteristic. I've gotten used to it.
[QUOTE]
I'd like to add to this thread that I too am experiencing a slight pull to the right. I own a G35X with the factory wheels and tires and the car only has 500 miles on it (only 15 miles on it when I picked it up). It's not a huge pull to the right but it's enough that I noticed I'm always holding the steering wheel slightly off center and to the left. The tires are all inflated exactly to spec as well. I notice it a little more at highway speeds than I do around town. Should I take it in to see if the tires are wearing off center or if it's my steering wheel that's out of whack...or should I give it a little more time and let the car's components break in a little better?
Me too
I've noticed my car also pulls slightly to the right. This seems to happen when I come to a stop. When I'm driving and let go of the wheel the car seems to hold a steady line in the lanes. It seems more pronounced if the road is uneven. Anyway, I think I will have the dealer take a look at it on my next/first service.
Looks like I'll be making my first visit to the dealership in the coming days.
Originally Posted by G35Now!
To close the story, the G kept pulling right for several days, then it seemed to go away. So, don't know if the alignment got changed slightly (don't recall hitting anything) then the tire tread evened out, or what. Tracks perfectly straight now tho...
Originally Posted by wpv123
yep... same here. mine pulls to the right at random times while driving and when braking. I feel better now reading this thread that it is a common issue and may not need an adjustment.
Took the dealer and they checked it over and said it was operating within spec.
They also gave me the BS excuse about road crowning, etc. as if I was an idiot and didn't take that into account.
Problem is my G pulls on perfectly flat roads, and even when i'm on a freeway that has a crown angle opposite to the pull!
This is NOT NORMAL, none of my other cars (BMWs, acuras and hondas) have experienced this...
hopefully you guys have better luck with your dealers.
