How do I answer in private when bluetooth is on?
Old Jun 30, 2007 | 08:34 AM
mbhforum's Avatar
Originally Posted by Estal8r
If you've got BT enabled and your phone is paired to your G, when you accept an incoming call you can switch to using the handset by using the touchscreen and selecting use "use handset" option. If you're using a flip phone just be sure to have your phone open prior to switching to the handset.
Or if you want, pull over and have your passengers get out while you answer your call!
What touchscreen? Are you referring to the people who have Nav? I don't have Nav, so I am not able to select touch screen, I have to use the buttons.
Old Jun 30, 2007 | 10:14 AM
HungNg85's Avatar
Press and hold talk button on steering wheel for 5 seconds to disconnect.
Old Jun 30, 2007 | 10:45 AM
terrycs's Avatar
Originally Posted by mbhforum
Do these exist? Isn't it up to the phone to decide priority? How does the headset even know about the car? It only knows about the phone, right?
Maybe it's phone dependent ... I have an AT&T 8525 (WM5 OS) paired with a moto H700 headset AND to the G35. If the heaset is active (boom open) the call goes through to the headset. If I take off the headset and turn it off (boom closed) the call goes through to the car.
Old Jun 30, 2007 | 01:29 PM
mbhforum's Avatar
Yes, it's phone dependent. Does Windows Mobile 5 give you the option to set priority on your phone? It must and you must have your headset as # 1. That is an awesome feature.
I have a H700 headset and a Blackberry 8700 (through work, so I am stuck with the Blackberry line) and even if I transfer the call from the car back to the handset, and then open my boom, it doesn't work, I have to manually turn bluetooth off on the car or disconnect the connection from the phone first before pairing to my H700. It's a real pain.
Old Jul 4, 2007 | 04:21 PM
treacherous's Avatar
20 Year Member
G35x
Originally Posted by hyukki
On my phone, (VX9900 aka enV) after I answer the call, I can press the "Ok" button twice to switch to my phone. Just like how you can switch from the BT headset to your phone and vice versa.
How is the sound quality/reception of your 9900? My wife was thinking about getting one to replace her 8100. Any BT quirks in the G?
Thanks!
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Rinaldi
Dec 2, 2015 05:29 PM
Learned Hand
Oct 1, 2015 09:02 AM
joel extreme
SOCAL Meetings & Events
Sep 29, 2015 04:44 AM
