Air Conditioner Problem??
The other day my air conditioner was barely blowing out my front vents even though it was set on the highest fan setting and the mode was set to front. This lasted for about 6 hours and then all of a sudden it just started working again with no changes by me. I had an appointment with Infiniti for this Monday, but I wanted some outside opinions before I let them start taking my dash apart to fix a problem that as of right now fixed itself.
Thanks in advance everyone.
wow thats weird how they just started working after 6 hours??? i wonder what made it react like that. Let us know what Infiniti sez...most likely theyll get in and be like..i feel air i dont know what your talking about lol they always act like nothing is wrong
mine usually a couple seconds..
DID YOU HIT A BIG BUMP WEN IT WORKED AGAIN? =) thats how my subaru is.. when something gets weird.. i hit a big bump and it all works out..
if i did that in my G .. i'd bend my rim..
Originally Posted by Gorn
Just checking, but you're *sure* it wasn't on automatic, right? Try turning it down to 60F?
Yeah, because I remember switching back and forth from auto to reg to see if that would make any difference. Either set set at 60 degrees wouldn't create more than a slight breeze from the vents; but it was sure making a lot of noise in the dash. Everything has been working for a few days now. Just seems strange that it would all of a sudden stop working and then start working again.
Similar Issue
I had a similar issue with a new Forester that we have. It turned out to be a solenoid that directed the airflow. It sounds like the fan is still running, so I assume the air is just not being directed to the vents. Was it coming out of the defroster or floor vents instead?
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
Jiggerjuice
Oct 5, 2015 02:33 PM
