What kind of HID's do we have?
Old Aug 23, 2007 | 01:32 AM
vodkarocket's Avatar
Modded Member
Chris, are you doing this after seeing my lights?
Old Aug 23, 2007 | 04:43 PM
cnugs127's Avatar
Originally Posted by G35PS
Seems like everyone answered your questions.
They are D2S, and you aren't gonna get better output with 6000k.
Just only blue color.
Far as output is concerned, keep anywhere from 4100 to 4300k.
Running 55w bulbs with 35w ballasts; not a good idea.
i believe i got the kit with 55w ballast.
one webiste says that 35w 4500k bulbs = 3400 lumens
and that 55w 6000k bulbs = 4800 lumens
This could be inaccurate. Can anyone comment?
Old Aug 23, 2007 | 05:44 PM
Triton3.5's Avatar
I would think that if your gonna change your ballasts 50 0r 55 watt, from 35 you should be real good no matter what "bulb" you put in the projectors,, most people just do bulbs, and either think, they are getting brighter light output, (lumens) or just want that 6000 to 8000 or whatever color, (kelvin) I am leaning towards 55 watt, 5000 lumens, but, I just don't know enough about HID lighting yet to pull the trigger on this matter. IMO, the headlights in our sedans are quite good but, i usually can't leave well enough alone Just today, Very foggy going to work 2 to 3 hundred ft. visability plus at 3:30 am, very diff. to see anything! maybe if our integrated fogs were not so worthless regards...
Old Aug 24, 2007 | 02:26 PM
HungNg85's Avatar
That sounds correctly to me. Please notice the big different is 35W and 55W. So even you go with higher keven temp. you still get more lumens.
Our stock wiring for low beam can support 55W. I believe fog light is 55W halogen too.
Old Aug 27, 2007 | 12:57 AM
cnugs127's Avatar
I was on the border about changing out the lights, but after seeing yours I was sold - thanks Boris!
Old Sep 9, 2007 | 12:51 PM
brooklynite's Avatar
can anyone confirm that our stock ballasts can handle 55w burners?
Old Sep 9, 2007 | 07:06 PM
cnugs127's Avatar
Not sure, but I don't think they can. I installed aftermarket ballast along with my aftermarket lights.
Old Sep 10, 2007 | 12:12 PM
HungNg85's Avatar
Definitely NO. Each ballast can only handle a specific wattage. Our stock can draw up to 35W. If you put in 55W bulb, you will see it light up yellow light, then flicker and then off completely.
Old Sep 20, 2007 | 09:28 AM
IvoryPearl07G's Avatar
are there 35w 6000k bulbs i can purchase and swap in for the more blueish look?
I have just ordered a plug and play HB4 kit for my fogs(they will be yellow). they should compliment each other.
but you all say i should go with a full 55w ballast/bulb kit, i will.
Old Sep 20, 2007 | 10:21 AM
stinky's Avatar
My understanding is that higher color temp means a darker coating on the bulb and less light output for the same wattage. Higher color temp (more blue light content) also means more glare in fog, not less. Selective yellow lights which are recommended for fog run in the 2500-2900 color temp range. Here's a source.
http://autolamps-online.com/halogen/goldcentre.htm
* An incandescent lamp emits a light of all colours, that’s called "continuous spectrum".
* The human eye is especially sensitive to the yellow light (wave length around 550 nm)
* That means a source emitting 10 Watts of yellow light will seem brighter than 10 Watts of blue light, since the eye is a lot more sensitive in the yellow region than in the blue.
Here's another source:
http://www.danielsternlighting.com/t...ght_color.html
You may want to consider 9006/9005 bulb swap/surgery, detailed here:
http://www.bmwe34.net/E34main/Upgrade/More_light.htm
Or even go to 9011/9012 bulbs, but they are higher color temp, not lower. But bear in mind that more light may not lead to better visibility down the road; it only helps visibility right in front of you. Good discussion of this here:
http://www.tundrasolutions.com/forum...hawk-opinions/
I am not a lighting expert, just a web junkie. I did the 9005/9006 swap on my old 1991 infiniti and the results were fantastic; YMMV. I used the Philips VisionPlus bulbs, which I believe are around 2900K, but look very cool.
heynow
2nd Gen (V36) Sedan
Oct 28, 2015 05:09 PM
stratous01
Oct 7, 2015 10:19 AM
NyCrAzY
Oct 1, 2015 09:19 AM
Atwork
Intake & Exhaust
Sep 20, 2015 03:36 AM
twentyeggs
Sep 11, 2015 03:58 PM
