Alittle help please?
Old Sep 25, 2007 | 05:12 PM
Briank212's Avatar
Hey guys, i have about 7600 miles on my g35x 07 and acouple of days ago i got a maintnice alert on my dash. i recently got the car serviced at 4500 miles. the alert just says MAINTNICE TIRE.. can someone tell me what this means? im going to schedule an appointment.
Old Sep 25, 2007 | 05:22 PM
CalsonicVQ's Avatar
Don't worry about that. That is a maintenance reminder that you can manually set. That reminder will pop up every XXXXmiles that you set it for (I set mine to 0miles, i.e. off) You have to play with the trip computer (use the two buttons on the right side of the dash board) to set/remove it.
Old Sep 25, 2007 | 05:41 PM
treacherous's Avatar
20 Year Member
G35x
Car has to be running and stopped to reset as well.
Old Sep 26, 2007 | 01:03 AM
DaCurryman's Avatar
to answer your question, it means it's time to rotate your tires. it'll go off every 7500 miles (from the time you reset it)
Old Sep 26, 2007 | 10:17 AM
kring's Avatar
I had the same thing, you have to go in through the touchscreen settings, I set them all to 0 miles so it doesn't bother me. The tiers was annoying because I can't rotate my tires.
AuAltima3.5
Cooling
Sep 13, 2015 10:46 AM
AmateuRN
South
May 22, 2006 05:23 AM
AmateuRN
Drivetrain
Oct 25, 2005 11:22 PM
AmateuRN
Jun 14, 2005 04:49 PM
