Jack Points on 07 Sedan?
Old Oct 7, 2007 | 10:54 AM
G35BlackonBlack's Avatar
Can anyone post up a picture of where the jack points are on the 07 Sedan. I saw a diagram on here for the 05, but am not sure if it has changed for the new 07 sedan? I am trying to change my oil, and am not exactly sure where to jack the car up at? Help!
Old Oct 7, 2007 | 12:13 PM
Joe_Camel's Avatar
There's a pretty good chance the jack points didn't change a millimeter, but just in case, you should be able to find this information in your owner's manual (maybe you didn't get one?).
Old Oct 7, 2007 | 08:26 PM
No, I have the owners manual, but do not see a diagram at all? Just states to use the appropriate jack points, but doesn't tell you where they are?
Old Oct 7, 2007 | 09:32 PM
tg1234's Avatar
Pg 319 explains clearly.
http://www.infiniti.com/iapps/techpubs
TG
Old Oct 7, 2007 | 11:40 PM
Sieveboy's Avatar
I just slipped the big floor jack under the lower control arm.
Old Oct 8, 2007 | 08:54 AM
Thanks, but I was looking for where we can jack the car up in the front and back center points? Has that changed from the previous version? For the front center, is it right in the middle of the cross member? I see a slight circular bump in the metal with a hole in the middle of the bump? Is that it? I just want to make sure I am jacking it right!
b2autodesigns
Accessories-Vendor
70
Feb 25, 2017 01:12 PM
DRG35R
Jul 31, 2015 10:23 AM
joedaddy1
Jul 28, 2015 02:58 PM
