Dealer won't apply CC TSB unless CC actually has a problem
Old Nov 9, 2007 | 02:46 PM
Lemodular's Avatar
help me decipher this line form the CC TSB:
JNKBV61 E (*) 7M 728124 / 03-Jul-2007 (without Intelligent Cruise Control)
my vin is less than the "728124," so would I qualify for this TSB?
Old Nov 9, 2007 | 02:56 PM
infi07g35x's Avatar
NUCLEI-G
Call this number OPtion 7 and give them your VIN. They can for sure tell you yes/no.
8006626200
Old Nov 9, 2007 | 03:04 PM
Lemodular's Avatar
thanks, I answered my own question by looking closer at the TSB. It states Vin #'s before the above numbers. So I'm in range.
Old Nov 9, 2007 | 03:17 PM
infi07g35x's Avatar
NUCLEI-G
yes, no problem.
Old Nov 9, 2007 | 04:25 PM
sunmind's Avatar
I do not mean to be too gloomy but it is realistic for some dealers to not want to spend their time "fixing" something because a customer thinks there may be a problem or the customer has read somewhere that it might make their car feel better.
If you go the service guys with a downloaded copy of the TSB and explain that your car has a tendency to "surge" and you request them to use the fix provided by Infiniti.. expect to get it done. The worksheet will describe this job having been done, at no charge to you.
If they object, simply insist that they advise you, in writing that they refuse to perform the warranty work and why. If they remain reluctant to do this, go to another dealership with the different approach outlined earlier. Meanwhile, send a copy of the written refusal from the first dealer, to Infiniti.
Old Nov 9, 2007 | 04:50 PM
infi07g35x's Avatar
NUCLEI-G
Which dealership do you work at? Thanks for the Input.
Old Nov 9, 2007 | 05:13 PM
G35Law's Avatar
My dealer wouldn't do the TSB either, even though I have the surging issue. They just burnished the brakes to solve the problem. I'm heading back on Tuesday.
Old Nov 9, 2007 | 05:35 PM
taltek's Avatar
I believe the dealer in my case... My build date is July /07. My VIN is within a hundred or so WITHIN the TSB affected pool. The full text of the TSB (the tech instruction set) says:
1: If the VIN is within scope and customer complains of CC surge, update ECM.
2: Once hooked up, if the existing part#/ECM ver is blank on the computer, no flash is available. I was speaking with the tech foreman who gave me a copy of the full TSB and my data.
Old Nov 9, 2007 | 06:39 PM
Nick 99's Avatar
__________________________________________________ ___________
Same thing for me....no flash available. The tech printed the step by step docs to show me he was unable to the reprogram.
Nick
Old Nov 9, 2007 | 08:37 PM
CalsonicVQ's Avatar
Okay...good news and bad news for me. I dropped my car off at 7am and didn't get a call from the dealer even though it was already 3pm. Besides the CC TSB, I wanted an oil change and a couple other things. It really shouldn't have taken a whole day.
Anyway, I just head over to the dealer and see my car in the service bay with a laptop hooked up. Apparently, they were doing the CC TSB!! YAY!! So the service advisor says 30more min. I wait 30 more min and then the service advisor tells me that they have a problem. He shows me the tech instructions (that includes the various computer screen shots) and says that the update program froze on step 26 of 30 or something like that (the progress bar on the screen hasn't moved for half an hour). ARRRGGGHHHH!!!!! Also, they can't call Infiniti technical support since it's already 4pm PST. Also they don't want to disconnect the cable/restart the program for fear the ECU will get messed up.
So this is means I get to drive their loaner base 07' G sedan for the whole wknd. At least they told me don't worry about the gas and that I don't have to re-fuel when I return it. I think I should drive and flog the loaner all I can this wknd. =P
I just hope they don't return my car to me on Monday with the original ECU program. Geez, definitely not a good experience for this first visit at this particular dealership.
Old Nov 9, 2007 | 10:30 PM
infi07g35x's Avatar
NUCLEI-G
Good luck, keep us posted. Having a loaner 07 does not hurt for over the weekend.
Old Nov 9, 2007 | 11:17 PM
silverG2007's Avatar
If you live in flat land (like me), use a bridge or on ramp and that's enough to feel the surge.
My dealer just took my word for it that I had the surge.
The TSB doesn't require VERIFICATION. It only requires that you SAY you have the surge.
So, why would the original poster say they DON'T have the problem? DOH!
Old Nov 9, 2007 | 11:18 PM
For the guys built after 07/07, don't worry about it, you shouldn't have the problem. I test drove one built in July, there was a noticeable difference in throttle sensitivity.
Old Nov 10, 2007 | 12:19 PM
Nick 99's Avatar
__________________________________________________ _____________
The TSB requires VIN/part #, if the # does not apply then there is no reprogram.
Old Nov 10, 2007 | 11:52 PM
  #30
NationsMostWanted's Avatar
Originally Posted by blindS!de
+1 to what everyone said... I had to lie about the surge just so they would do something, they told me that only if the customer felt the problem or recall then they would fix it so lie lie and lie some more...
how is the dealer in Fresno when it comes to warranty stuff?
leo38cheng
Nov 12, 2015 06:49 PM
Jiggerjuice
Aug 17, 2015 08:41 AM
D1dphresh
Aug 7, 2015 06:10 PM
Detailed Image
Aug 7, 2015 02:10 PM
sailfish250
Jul 30, 2015 11:39 AM
