is it ture that G35 Sedan is faster???
Old Nov 24, 2007 | 10:58 AM
barrister89's Avatar
The Edmunds driver got 13.9 with an AT coupe.
http://www.edmunds.com/insideline/do...ticleId=108901
Pretty much neck and neck with sedan. But you get this car for the handling, not the drag strip, right?
Old Nov 24, 2007 | 11:17 AM
ratm68's Avatar
Originally Posted by vstrizheus
No, they don't. There are several people who have run 13.7's already w/ the G37S. One was an automatic.
That may be true, but i wouldn't put too much money into the car magically improving by a couple or few tenths stock.
Old Nov 24, 2007 | 12:28 PM
CrazyRuskie's Avatar
Well, lets put things into perspective. The best the mags ran an 07Z was a 13.8... best stock times for non-mag drivers (owners) are 13.2-13.4's consistently. Does that mean they are "magically" improving by a couple tenths? Its not magic, its called practice. You can't masterfully drive a car the first time you get it, you learn how to launch correctly & shift it right, you will improve significantly. The 6MT that ran a 13.7, it was his first time at the track. I will be taking mine to the track in the Spring, and we'll see what its really capable of.
Old Nov 24, 2007 | 01:23 PM
tg1234's Avatar
There are some factors can change your "stock" car. If you go on the track lower your tire pressure possible change your tire. Higher octane gas, Take all the extra weight from your car don't go with full tank of gas .These are just a few options to improve your 1/4 run. We still can call ths car stock but it will be faster.
TG
Old Nov 24, 2007 | 07:25 PM
gspot35's Avatar
Magazine's don't powershift like owners do. All shifts are lift throttle when magazines review. Auto to auto should tell the story....anyone have a read on that comparo?
Old Nov 24, 2007 | 07:33 PM
Best I ran w/ my wife's 07 5AT was a 14.0xat the drag strip
Old Nov 24, 2007 | 09:37 PM
gspot35's Avatar
Remember your 60' time?
Old Nov 24, 2007 | 09:53 PM
2.145. There is definitely room for improvement, I think I could have had a 13.9x if I ran a few more times.
Old Nov 24, 2007 | 10:09 PM
tg1234's Avatar
Take all the weight out from your car. spare tire, back seat go lower tire pressure and not more then half tank gas and you can go .3 lower for sure.
TG
Old Nov 24, 2007 | 10:23 PM
gspot35's Avatar
2.145, yep there's a lot of room for improvement. I think most magazine testers power brake to try for the fastest times. Tell me, did you have to control wheel spin in the G37 auto?
Old Nov 24, 2007 | 10:55 PM
mal_TX's Avatar
The G37S that ran a 13.798 was a 5AT... stock, fully. And it was his only/first run, ever. The G37 is under-rated by mag racers; it is faster than the G35 Sedan and the old coupe, and not just by a little bit:
http://www.myg37.com/forums/showthread.php?t=174961
Originally Posted by KAHBOOM
Thanks
Actually I have the 19s
VDC off
Just slammed the pedal and let the torque converter do it's job (got very little wheel spin)
Used full manual mode and shifted 1-2 slightly into redline- actually that was driver error but apparently it didn't hurt and I got a nice kick in the butt shifting into second.
However I did have just shy of 30 miles of gas left. It gave the warning down the track. So that saved some weight.
I think the biggest aid was the cool crisp air (low 50's) and a near perfect launch- still basically a 13.8
Old Nov 25, 2007 | 12:20 AM
GNN60GT500's Avatar
13,7-13.9 unless your running at least a mid 12 its all slow to me- neither the G37 or the G35 are a fast car- they are peppy but neither are fast-
Get which ever one you like better, but dont buy one just because it is faster because if speed is your concern, there are better options out there
Old Nov 25, 2007 | 12:51 AM
AlterZgo's Avatar
There are a couple of G35x ATs which have run 13.8s. G35s should be a bit quicker due to less weight.
I think through the 1/4 mile, both cars will be very close. However, past the 1/4 mile and at higher speeds, the G37 should start to pull away due to the higher top end HP and better breathing thanks to VVEL.
Hey, I was right. According to the C&D articles posted earlier:
G37 0-150: 36.2
G35 0-150: 38.2
Still, in most real world driving situations, it should be a driver's race.
Since you own both G37 and G35, does the 37 feel significantly quicker than the 35? Have you ever run both against each other?
Old Nov 25, 2007 | 01:20 AM
I haven't yet, but I will run it against an 07Z this spring.
Old Nov 25, 2007 | 01:21 AM
  #30
I don't know what world you live in, but 13's in the 1/4 is plenty fast. They just aren't supercar fast.
