ITB 07-045 2007 G35 Sedan; Cold Engine Start Issues
Old Dec 2, 2007 | 09:24 PM
treacherous's Avatar
20 Year Member
G35x
I am sure glad to see this one. I have this issue and dealer could not address when I took my G in last month.
http://2007.infiniti.g35x.googlepages.com/ITB07-045.pdf
Drivability issues as follows:
• Rough idle during the first minute of engine operation after cold engine start.
And/or
• Slight engine speed fluctuation during light throttle acceleration during the first ten minutes of driving
after cold soak.
NOTE: This issue, if it should occur, is related to engine temperature. It is NOT related to ambient
(environment) temperature.
Old Dec 2, 2007 | 10:20 PM
808MIKE's Avatar
hmm gotta check to see if mine does this. where is the ECM or ECU #'s to check at? Location?
Old Dec 3, 2007 | 12:27 AM
JCFW's Avatar
Originally Posted by treacherous
Actually there isn't a way to see version without dealer's Consult III. My vehicle's ECM was upgraded to version "B" on the listed work order when I took in for cruise control surge. This new rev would take it "C".
Dude, thank you so much for this info. I have been having this problem for over 2 months, and the dealer can not find the problem... (they say that l have to remove my stillen intake, and exhaust) before the will recheck the car. This really helps. Thanks.
Old Dec 11, 2007 | 09:23 PM
three's Avatar
Had this done last week and seems to have fixed the problem.
Old Dec 12, 2007 | 10:20 AM
jdanielsg's Avatar
just a question, are you allowing the car to come down in rpm b4 driving off? in my old car you turned it onm it reved itself to say 2000 or something..then slowly comes down to 1000 or under in a lil bit, if I drive before it does that, it drives all stupid LOL
Old Dec 12, 2007 | 11:54 AM
jdanielsg's Avatar
ok keep us updated
Old Feb 8, 2008 | 10:04 PM
DRob's Avatar
Same issue here. I got sick of the cold start herky jerky moves, how embarassing. I could litterally see the RPMs dip and flick back and forth. Did all of the above: switch to DS, down shifted manual mode and finally took it in. I got a loaner journey and felt a big difference right away. It seemed that my Sport 5AT was running lean and the Journey responded as you punched it. I also noticed that prior to the ITB update that my car was shifting prematurely. Drove it home today and so far so good.
Old Feb 10, 2008 | 01:48 PM
JCFW's Avatar
And/or
after cold soak.
I had my car serviced with the above bulletin. I printed all the pages and showed it to the dealer, and they followed the instructions, and presto, all problems was fixed. Also it does state that u should have 5W30 motor oil for this car.
Old Oct 5, 2011 | 07:17 PM
lundy's Avatar
Sorry to bring back up an old thread but my car is doing something similar. Upon cold starting it will rev to 2k for a moment but then drops down pretty rapidly to about 1200 and sputters a little bit before it catches itself about to die and revs back up to 2k and warms up normally. Thoughts?
chinee
Jun 10, 2024 07:48 PM
vmcarbuyer
Oct 12, 2019 12:42 PM
ClwMike
Jul 23, 2015 12:55 PM
