07/08 auto, does ur car jerk when you shift?
Old Dec 18, 2007 | 04:09 PM
jdanielsg's Avatar
does your car jerk/move when you go from park to N to drive or whatever.. vice versa.... do you also feel resitance when you are pressing the button and trying to move it.
Old Dec 18, 2007 | 04:13 PM
fecurtis's Avatar
No.
Do you park on inclines or declines without using the parking brake?
Old Dec 18, 2007 | 04:15 PM
jdanielsg's Avatar
nopes. level ground parking brake not on.. shifting from park to whatever it jerks.. do you press the button just to get it past park then push it button free to drive or ?
Old Dec 18, 2007 | 04:22 PM
fecurtis's Avatar
Yeah I just push the button to get out of park then release it as it'll automatically move out of neutral to go into drive if I simply just pull it down.
I've never had that jerky issue though.
Old Dec 18, 2007 | 04:24 PM
tagheuer's Avatar
mine jerks, on a cold start, from park to reverse, or from park to drive.
Even worse, my transmission gives me a hard shift from 1st to 2nd when cold, it almost feels like it is slipping a little...
I'm really not happy about this, it performs this feat about 1 of every 4 cold starts...feels like the transmission may be starting to fail, at only 11k!!!!!!!!!
I plan on taking my car into the dealer soon.
They haven't been able to fix anything, my car has also had a slight pull to the left since the very beginning, and they claim its "within normal operating specs" and my A/C smells musty, and their suggestion is to turn off A/C a few minutes before shutting the car off, that is really inconvenient, and defeats the whole purpose of the "automatic climate control".
If I wanted these kinds of problems, I'd go back to BMW, at least I'd get a better driving feel.
I'll let you know what the dealer says, I'm pretty sure they'll be "unable to reproduce the condition".
Funny how my neighbor across the street, who is a very high ranking engineer at Nissan North America, notices the pull to the left and the transmission jerk, and thinks both are things that need to be fixed...
Old Dec 18, 2007 | 04:27 PM
hyukki's Avatar
The AC will, in almost every car, smell musty if you are not careful depending on climate, location and other factors.
Old Dec 18, 2007 | 04:34 PM
tagheuer's Avatar
uh, not in my experience. I have owned Nissans, Hondas, BMWs, Chryslers and Fords over the years, and have NEVER encountered this problem.
Old Dec 18, 2007 | 04:40 PM
jdanielsg's Avatar
well my car is brand new and it jerks so I dunt think its a wear issue. It seems warmed up but I will monitor and see.. so r u saying ur car has no movement whatsoever when u change gears totally smooth, no resistance..no movement whatsoever.. its not the car moving but the tranny.. which I am talking bout u can sorta feel it make the change
Old Dec 18, 2007 | 06:07 PM
G35Now!'s Avatar
Moderation-free
Not sure I would call it a jerk, but then I let the RPMs drop down to 1,300 before shifting to R or D. If you don't do that, and shift immediately (with the RPMs close to 2k), I can see where you would have the torque converter wound up enough to create a jerk.
Old Dec 18, 2007 | 06:50 PM
jdanielsg's Avatar
i know thatone.. so far I havent seen the car rev...to 2K or stay that way for any amount of time anyways
it always falls right back under 1K.....i will check again later
Old Dec 18, 2007 | 06:58 PM
Art007's Avatar
I don't feel a jerk at all. The G is garaged overnight and is not very cold in the morning.
Is the 'snow' button off? Just a thought.
Old Dec 18, 2007 | 09:00 PM
jdanielsg's Avatar
yes its off.. well I let the car settle to just under 1K I think is what its resting at.. it revs only for a tiny little bit. then comes down quick to just under 1K.. but it will only stop being jerky after some driving.
Old Dec 19, 2007 | 08:46 AM
IvoryPearl07G's Avatar
mine is garaged, but i work night shifts.
when in the garage and cold starting if i shift into drive/reverse after about 10 seconds there is no jerk(unless its below 30 outside).
when at work and its outside, i cold start it and shift into drive after about 10 seconds, it jerks everyime(if its below 50 outside).
but thats only if i dont have the brake firmly pressed. I am used to it and i know its the car trying to warm up by keeping the revs up. most new cars have that programming to help it warm up, its mostly an emissions thing(heating up catalyst), but it also helps when sitting in park/neutral waiting for it to warm up.
either firmly apply the brake when first putting it into D/R. Or wait for the revs to drop after 15-30seconds and then shift it out of park.
Old Dec 20, 2007 | 10:21 AM
MrJackSprat's Avatar
Cold Start Issues
Infinity has released a service bulletin on these cold start issues. Please visit...
http://x.infinitihelp.com/forum/loca...s.php?catid=77
Old Dec 20, 2007 | 11:07 AM
Mr Inkredibul's Avatar
YEah the musty smell is normal for new cars.
