Gas Tank Capacity Question.
Old Jan 12, 2008 | 03:51 PM
  #31
Grav's Avatar
I'll take a last stab and see if we're done.
Oliver, I think you're wondering whether the system will "learn" and adjust itself to you. Not in this case. Every time you fill up the settings will remain the same with the warning coming on at the same point as you empty the tank.
Old Jan 12, 2008 | 03:57 PM
  #32
treacherous's Avatar
20 Year Member
G35x
Originally Posted by kring
Now I do think that extremely low fuel may burn out a fuel pump if it's sucking air. But I am also skeptical that Gas is a "coolant" for a fuel pump. How hot can a pump get thats pumping 1 gallon every 20 minutes... we're not talking about a commercial sump pump blowing out 20 gallons a second here.
I never thought about this myself until I bought a EFI based Polaris ATV back in '04. It states in it's manual that in-tank fuel pump is cooled by the fuel and to not let the tank go dry. While it is not pumping a lot of fuel it is under high pressure so that may contribute to the heat production. I'd think this would probably occur with my G's fuel pump as well. Just my 2 cents. :-)
Old Jan 12, 2008 | 04:03 PM
  #33
20 Year Member
G35x
It appears from SM that fuel level sensor is set to go off at (3-1/8 gallon, 2-5/8 imp gal) or less.
Old Jan 12, 2008 | 05:49 PM
  #34
AesonVirus's Avatar
Careful Threach... you don't want to offend anyone!!!
Old Jan 13, 2008 | 12:26 AM
  #35
Oliver514's Avatar
Aeson, I didn't mean to flame you, but like I said I used the search function and did NOT find my answer. So the "use the search it has been talked about" comment annoyed me. Didn't mean to blow up on you.
Thank you. I found the answer I was looking for. I really appreciate the input.
Old Jan 13, 2008 | 11:08 AM
  #36
ABQ_G35's Avatar
It's any fuel pump in the tank, everyone I've know who has run out of gas, with an FI vehicle, pump in tank, has eventually had a fuel pump failure. What I was told is the gas serves as a lubricant for the pump.
Old Jan 13, 2008 | 12:55 PM
  #37
20 Year Member
G35x
I'm pretty careful at this point to never go below a 1/4 tank before I refill to full in any of my motor toys and vehicles.
Old Jan 17, 2008 | 05:00 AM
  #38
Vitorio's Avatar
Last time I remember that my car was really low on fuel and it went saying 30miles left ‎but after that it just showed ----- left!!! it never went under 30 maybe, I never saw it ‎saying 1 mile left!!! Is this normal?‎
Old Jan 17, 2008 | 08:07 AM
  #39
DeadCellShadix's Avatar
I try to keep my car at 3/4 to Full at all times. I guess it hurts me less mentally when I go to fuel up and it only costs me $8 - $10 haha. But I do it like every 2-3 days :/ At least I work on a base where most of the time gas is $.05 cheaper ><
Oh ya, question. How bad would it hurt your car if you put regular gas in it for about 2-3 months not reallizing that you should only put premium in it because you're too much of an idiot to reallize the inside of the gas lid says "premium only"....ya I did that
Old Jan 17, 2008 | 06:36 PM
  #40
Triton3.5's Avatar
shouldn't be no big deal... the knock sensors will adjust timing seamlessly, sometimes you have to get regular grade fuel... you can also just drive the car normal, ie, stay out of the throttle, but not much fun with these cars
Old Jan 18, 2008 | 06:57 AM
  #41
KJC5050's Avatar
Why??
Old Jan 18, 2008 | 07:24 AM
  #42
07-G35-MT/S's Avatar
A little food for thought.
I recently parted a car out, and in the process, sold the gas tank. The car had 105k on it. I didn't want to store the tank in my garage with gas in it and the top open. I drained the gas into my mower gas can. Let me tell you, there was NO sediment buildup in the tank. NONE. I was suprised myself.
So, from my experience, the scum / sediment at the bottom of the tank statements, don't really hold up.
Old Jan 18, 2008 | 11:00 PM
  #43
blbncsu's Avatar
I've designed fuel tanks and fuel pickups etc...
First you never have your fuel pick up at the very bottom of the tank. So unless you have a tank with a whole lot of dirt/sediment, that isn't a concern. Your fuel pickup has a rough filter and then you have a finer fuel filter. You design to have the fuel gauge go to E or in the red once you get to a conservative fuel level (15-8%) of tank volume. Fuel does serve as a pump coolant, a large tank of fuel is a good "heat sink".
Fill up like a normal person and your good to go.
Old Jan 19, 2008 | 01:06 AM
  #44
oughttoreturn's Avatar
I have not filled up with my G with a full tank of gas. Gas is too expensive and I'm too broke!
______________________
2008 g35 journey ivory/stone with prem and sport pkg.
Old Jan 19, 2008 | 09:56 AM
  #45
AesonVirus's Avatar
You have a 35K trophy??? LOL
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
g.spot
May 9, 2016 10:54 PM
BradMD_96
Oct 6, 2015 09:31 AM
Hogbone
Sep 28, 2015 06:44 PM
