How to Get Dealer Fix? G35 08 Washi Panel Rattles
Old Feb 24, 2008 | 08:48 AM
onthebeam's Avatar
Question How to Get Dealer Fix? G35 08 Washi Panel Rattles
Hi all,
I've seen some other recent postings on rattles. Mine are frequent and on the increase even though my car is only one month old with 900 miles. Has anyone gotten a dealer to correctly fix these, and if so, what did they do? I've done lots of online searching and have found a couple of posts that seem to indicate a similar problem to mine:
Smooth pavement is fine. When I drive on only moderately rough pavement, I hear a series of fairly high pitched rattles. Some have described as like the ticking of a clock. It's almost like few clicks of sound as if when you spin a bicycle spoke. Or maybe, a mosquito zapper high pitched metallic sound. (By the way, these rattles have nothing to do with the stereo-even if it's off I get the same annoying problem)
It's mainly coming from the right side. My best guess is that, since it's a metallic sound and coming from that area, it is in the washi panels, both front and back. I've grabbed the seat belts, etc., but that doesn't diagnose it.
It's driving me mildly crazy. My 8 year old BMW with 70,000 miles doesn't have a single rattle.
I hope some folks will weigh in as I really want to get this solved. I don't live near the dealer but will be taking it in two weeks from now to see if they can find it.
Old Feb 24, 2008 | 01:13 PM
YoshiiSON's Avatar
same issue
i had the same prob. after 2000 miles no more rattles, hope it works out 4 ya
Old Feb 24, 2008 | 08:10 PM
onthebeam's Avatar
Are you saying the rattles went away by themselves?
Old Feb 24, 2008 | 09:28 PM
YoshiiSON's Avatar
yess sir or ma'am the rattle went away after around 2000 miles, but maybe u should still take it to the dealer to have them look at it, i noticed with my car that the rattle would becme worse when the RPM's went above 3-3.5 but one day just woke up at it was all gone, i was acually thinkin it was the heater core, the 07's had a TSB on it but so far so good with my 08
Old Feb 25, 2008 | 05:47 PM
ulmguy84's Avatar
Seat rattle
I had a similar issue with my 08. I have about 6000 miles on it now. I was hearing a similar clicking sound, much like you described it and it definitely was coming from the passenger side. However, if a person would ride with me to diagnose, it would not rattle. I finally figured out that it was the seat itself. With a person in the seat, it would suppress the rattle. It was only when no one was in the seat I would hear it. I played around with the adjustability of it and found that if I lifted the seat straight up for like half a second it made the rattle stop. So.....my seat stays lifted a small bit. Problem solved! Perhaps its the same thing???
Hope this helps.
Old Mar 11, 2008 | 03:33 PM
onthebeam's Avatar
I took my car to the dealer to try to diagnose this. They tightened something inside the door panels and the problem seems improved.
I asked them to add weatherstripping inside the aluminium washi panels on the doors and they said the aluminum doesn't come off. That's in contradiction to what I read in earlier posts.
Old Mar 11, 2008 | 04:29 PM
08g35s's Avatar
I have about 3900 miles on mine and I started to hear these sounds recently. The sound comes from many places inside the car. I guess its just frame flexing.
Old Mar 11, 2008 | 08:27 PM
fecurtis's Avatar
Yeah I've had the same problem. Its definitely the passenger seat, when someone is sitting there the noise is gone.
Old Mar 11, 2008 | 09:17 PM
robswid's Avatar
Rattle
I have a metallic sound like springs rattling sometimes that sound like it is comng from the passenger seat. i do not hear it when someone is seated in it. I wonder if it has anything to do with the seat heaters?
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
slider_ua
Jul 29, 2015 04:17 PM
laksjd84
Jul 24, 2015 05:12 PM
Karnicle
Jul 23, 2015 05:08 AM
emorehs
Jul 17, 2015 09:45 AM
