Tire Problem. help needed......
Old Feb 25, 2008 | 11:24 AM
08g35s's Avatar
I am having problem with my rear right tire. I am loosing pressure for that tire always. Yesterday when I checked the tire pressure it was 9 psi. I filled it to 34 and today I am getting the tire pressure warning again. Before it used to show that warning once in four or five days, now it’s every other day.
Do I have a bad tire? If that’s the case what can I do about it? Can any one please help me…….
FYI I live in Florida, So cold weather cant be a factor
Thanks
Old Feb 25, 2008 | 11:43 AM
G35Now!'s Avatar
Moderation-free
Have you had it checked? Sounds like a nail, or (less likely) a bad valve stem.
Old Feb 25, 2008 | 11:44 AM
kamalster's Avatar
You serious? It's clearly not just the sensor, it's the tire itself. Take it into a service center and I'm sure they'll find a crack or a nail in it somewhere.
Old Feb 25, 2008 | 11:51 AM
Mr G's Avatar
You probably got nailed , sorry couldn't resist.
Bring your car to any local mechanic and have them check for leakage
Old Feb 25, 2008 | 12:04 PM
08g35s's Avatar
Thanks guys, I will take it to the dealer today.
Just thinking, will I be covered if there is any damage to the tire?
Old Feb 25, 2008 | 12:07 PM
kamalster's Avatar
Unlikely. Mfg warranties don't typically have road hazard coverage, so unless you specifically negotiated that with the dealer when you bought, I'd say you've got to pay. If it's just a small nail that's not in the sidewall and it can be repaired, it shouldn't cost more than $15-20, though. If it's in the sidewall or the hole's gotten too big, you'll be in for a new tire.
Old Feb 25, 2008 | 04:41 PM
08g35s's Avatar
Took it to sears this afternoon, they found a damm nail in it.
Old Feb 25, 2008 | 04:48 PM
kamalster's Avatar
Were you able to get it repaired or was the tire a write-off?
kamalster's Avatar
Based on how fast it was losing air, I'd guess it was a write-off.
Old Feb 25, 2008 | 04:50 PM
06g35meister's Avatar
did they fix it?
Old Feb 25, 2008 | 05:20 PM
08g35s's Avatar
They said they can fix it. I left the car over there.
Old Feb 26, 2008 | 10:30 PM
WUKILLABEEZ's Avatar
Thanks
What did you fill the tire up with, regular air? Did your car not come with nitrogen in the tires...
Old Feb 26, 2008 | 10:39 PM
G35Now!'s Avatar
Moderation-free
Mine came with N; after changing the tires, it's now regular air. Zero difference, even when one had regular air, and the rest N.
vitamin.v
Nov 7, 2019 06:10 PM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
mike730
Jan 12, 2018 04:25 PM
Fire0nic3
Aug 31, 2015 03:18 PM
Fireman07603
Aug 9, 2015 06:00 PM
