Need help with mantenance info screen.
Old Mar 3, 2008 | 12:48 AM
hans127's Avatar
"Other, oil, tires" maintenance reminder just went on today after setting it a month ago at 3500 miles.
Can someone clarify what the "other" means?? and I'm assuming "tires" means rotation right?
How often do you give your G an oil change and where do you get it done?
Old Mar 3, 2008 | 02:54 AM
CalsonicVQ's Avatar
If you set the reminders for 3500 miles, that means it will come on at 3500 miles intervals starting from time you set it. i.e. If you set it for 3500 miles when you have 1000 mile on the odometer, the reminder will come on when you have 4500 miles on the odometer.
The "Other" category is whatever you want it to be.
Personally, I turn all service reminders off.
Old Mar 3, 2008 | 03:30 PM
hans127's Avatar
how do you turn off the service monitor?
is it too late now that I have that annoying reminder going off or Is it something that the dealership has to do to turn it off or reset it? So this things is basically just telling me that I need an oil change and tire rotation? How often is it best to do a tire rotation?
Old Mar 4, 2008 | 01:10 AM
oughttoreturn's Avatar
I only use the change oil mode. If you have sport model or sport pkg then dont need to rotate tire.
______________
2008 G35 Journey 5AT Ivory/Stone+Prem&SportPkg.
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
Rose M
Oct 12, 2015 10:00 AM
TurTLe*
Sep 29, 2015 01:43 PM
ncg35guy
Sep 24, 2015 04:53 PM
wayneside
SouthEast
Sep 23, 2015 06:38 AM
