G35 Sedan: Do you have to slam your trunk?
Old Apr 24, 2013 | 01:32 PM
  #46
bluedevils95's Avatar
Never had to slam mine
Old Apr 24, 2013 | 01:42 PM
  #47
Proxy's Avatar
I had to slam my 2008 trunk too, or it would not latch and just sort of bounce. I added some sound deadening material to the trunk and it made it more solid and easier to close. No more slamming!
Old Apr 29, 2013 | 02:52 PM
  #48
Duk's Avatar
Duk
Originally Posted by vqsmile
I think the issue has to do with the articulation of the hinge mechanism. The trunk is pretty narrow, so to make it open as wide as possible to put larger items in, they needed the lid to swing up and away as much as possible. TO do this they used a hinge that, for lack of a better description, sort of goes "over center" if you will; moving both upward and backward. As a consequence, it is great for getting out of the way as much as possible, but when closing it, we tend to want to just push down on it with a single effort. This typically gets it "over center" again, but is not enough to go the extra distance to complete its latching. If you just learn to make your closing effort more of a two step operation, you'll find you get better results. I usually pull it a little toward me at the top (to get it "over center") and then give it the normal push down to close it; works every time.
.02
hmm, haven't thought about the physics of "over center", cuz i thought it more of a lube issue. but yes! pulling towards me does seem to do the trick. well put.
it is still a nuisance to have to even be thinking about this two stage process just to close a trunk (i know... first world problem... )
Old Apr 29, 2013 | 03:03 PM
  #49
calcul8's Avatar
I can haz potato?
sabertooth tiger
Sometimes I did experience with the newer loaners that I had to close the lid more forcefully than I do with my '06
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
laksjd84
Jul 24, 2015 05:12 PM
G35_EAZY
Jul 19, 2015 01:38 PM
