Anyone else have trouble pumping gas?
Old Mar 16, 2008 | 05:05 PM
NewGuyG35's Avatar
Maybe it's just me or my car, but sometimes when I need to put gas in the car, the gas pump will not allow me to continue putting gas. Ex; my car will need about 10 gallons, I get around six or seven gallons, the gas pump will start shutting off like if the gas tank was full. Anyone else had this problem?
Old Mar 16, 2008 | 05:51 PM
ampenner's Avatar
This happened to me at least 3 times at one particular gas station. Even if you moved the nozzle or retried 5 more times, the pump would just keep shutting off with at least 5 gallons to go. It's never happened anywhere else, so I just avoid that place. I figured it had to do with the pumps, not the car.
Still kinda weird though, I would've thought the design of pump shut-off mechanisms would be pretty much figured out by now...
Old Mar 16, 2008 | 05:54 PM
Mr.GEE's Avatar
20 Year Member
This was an issue with some 2003-2004 coupes. There was a TSB on this, where they replaced the filler tube going into the tank.
Old Mar 16, 2008 | 06:26 PM
MiniRX7's Avatar
have this problem with my 2007, i jsut pull the nozzle half way out and its all good!
Old Mar 16, 2008 | 06:35 PM
hawaiinpunch's Avatar
i have thge same problem..but it only happends in one particular pump!!
Old Mar 16, 2008 | 10:16 PM
kenasaki's Avatar
same **** with mine at this particular shells gas station. didn't matter how many times i re-angled the nozzle, same crap. but it doesn't happen to me all that much anymore. my friend told me that a service manager told him that if this happens all the time at multiple places, it means that something is wrong with the tank and they'll have to replace it.
Old Mar 16, 2008 | 11:29 PM
tg1234's Avatar
There is a valve if it happenes all the time they have to replace it. If it is only happening at one station then try not to pump there.
tg
Old Mar 17, 2008 | 01:16 PM
max2k1's Avatar
Try rotating the pump handle so that the control lever is now "on top" (rather than below the gas tank opening) -so essentially put the nozzle in normally and then rotate it 180 degrees.
I've read here that it has worked before on troublesome pumps like what you describe here.
Old Mar 18, 2008 | 12:15 AM
WUKILLABEEZ's Avatar
That has happened to me also but in my case it definitely isn't due to a malfunction of the car. Around here some of the gas stations put a limit on the amount of gas you can get, usually $50s worth. After I've pumped $50s worth of gas the pump cuts off and you can't get anymore. I think you can probably get around that though by starting a new transaction with a different credit/debit card.
Old Mar 18, 2008 | 01:44 AM
B L U E S L A T E's Avatar
Honda Accord
This happened to me several times.... few months ago. Now it seems to be okay again...
Old Mar 18, 2008 | 11:55 AM
max2k1's Avatar
Given where gas prices are headed, $50 would only buy me enough to fill up my lawn tractor a few times
Old Mar 18, 2008 | 12:07 PM
Joe Bass's Avatar
I think it is stopping so it can run your credit report.
Old Mar 18, 2008 | 12:30 PM
CoppellStereo's Avatar
this happens to me too, i thought it was just the pump, but i know how a pump acts when there inst much gas left in the underground tank, so i thought it was either a malfunction with my car or the pump itself. good to see i'm not the only one in the same boat
Old Mar 18, 2008 | 01:39 PM
MrJohnTan's Avatar
One of the two fuel sending units has gone bad. Dealer told me it was because I ran the car on empty for too long. Covered under warranty. Take it back to the dealer and they'll replace it for you.
Old Mar 18, 2008 | 04:16 PM
max2k1's Avatar
How do you manage to run the car on empty ??
please tell me -- I could save a whole lot on gas bills
j/k
