Rear Climate Control Temperature
Old Mar 24, 2008 | 08:23 PM
DRIP's Avatar
I've searched the owner's manual and the site but struck out. If I'm in "dual" mode for the climate control with the driver at one temprature and the passenger at another, which setting controls the rear vents?
More of a curiosity than anything else.
Old Mar 24, 2008 | 08:44 PM
AesonVirus's Avatar
Those rear vents are nothing more than the front vents flowing through the arm rest and out the back.
Whatever you're set to in the front is what you're gonna get in the rear... there's no separate control or temp setting for the back.
Old Mar 24, 2008 | 09:04 PM
warzywko's Avatar
so if you set passanger @60 degrees ad driver @ 90 you will get 2 diffenet temps in the back??
Old Mar 24, 2008 | 10:58 PM
DRIP's Avatar
Yeah, that's really my question. I know there are no separate controls for them, but do they use the driver's side air, the passenger side air, or both?
Old Mar 24, 2008 | 11:40 PM
Jspeed's Avatar
CV35 6MT
I think you'll create a storm...
Old Mar 25, 2008 | 08:00 AM
tg1234's Avatar
Passanger side.
tg
Old Mar 25, 2008 | 09:55 AM
princealyy's Avatar
Something to check when i get to the car today
Old Mar 25, 2008 | 09:56 AM
rpm&my_G35's Avatar
Originally Posted by tg1234
Passanger side.
tg
This makes the most sense. People in the rear seats are 'passengers' to. If you want to confirm it then test it by setting one side on high and the other side on low and feel what comes out the rear vents.
Old Mar 25, 2008 | 10:40 AM
theimmortal's Avatar
I think you're right. When a cold and hot front collide, the hot front rises over the cold front and drops in temperature; this drop causes the moisture in the air to condense. Depending on the termperature of the air this moisture will fall down as either rain or snow.
Old Mar 25, 2008 | 12:01 PM
DRIP's Avatar
That's what promted the question. The kids said they couldn't tell the difference.
Old Mar 25, 2008 | 12:51 PM
tg1234's Avatar
It is a lot harder to heat up the back seat area since it is biger space and further. If you want to test it put driver side low and the pasanger side higher lot higher so you'll feel the different.
tg
Old Mar 26, 2008 | 05:32 PM
james0076ss's Avatar
I wish my 6mt had rear vents
Old Mar 26, 2008 | 11:00 PM
Jspeed's Avatar
CV35 6MT
Ya, the 3 series doesn't sacrifice rear vents for manual. It just takes some engineering.
Old Mar 26, 2008 | 11:19 PM
jl114's Avatar
Don't manual have rear vents under the front seats? The vents your missing in the manual suck anyways. You need to crank the fans up pretty high until you can feel something.
Old Mar 27, 2008 | 12:01 AM
kool_yaar's Avatar
manual
ya the 6MT does have the rear vents under the front seats and tehy are pretty good, move the front seats up all the way and you can see two ducts under each seat which exhale some nice air... and the rea is conttrolled by the passenger side temp.
