New owner- how to I get the analog clock backlight on? Brake vibration?
SubscribeHi all-
I'm the proud new owner of an 08 G35s LP with charcoal interior. Love it so far except for two things. The sweet analog clock in the dash should have a backlight, no? I can't seem to find where to turn it on. I adjusted the dash illumination all the way between min and max (the buttons to the left of the gauges on the cluster) but they had no effect on the dash clock. I noticed in a pic I saw that there is a glowing ring around the navi dial controller as well, and I can't recall if that was on or not in mine as well. Let me know how to get that clock glowing please.
I'm coming from a 2005 BMW M3 convertible, so this feels consideribly different. Still very nice, but much quieter of course, while still firm riding like I like. The steering on my RWD Sport model feels a little loose/numb compared to the M3, but it was an M3 after all. It would be nice if the steering assistance was adjustable to provide firmer feel, but this is a moderatly priced car after all. I can live with it and will get used to it.
One thing that is a slight concern is the brake feel. When braking I notice some shudder or vibration almost every time I brake. I never noticed that in the M3. They seem to stop just fine, then just feel a little rough doing it with the vibrations, even in normal around-town driving. Since the car is new I assume it was fully checked out by the factory, but should I check with the dealer on this or is it normal?
Also, my car is brand spankin' new, under 100 miles so far. I'm going to fully read the owners manual (what a tome) this weekend, but for the short version, can someone enlighten me about the proper break-in procedure? Thanks!
Thanks, just the kind of basic info I needed before digesting the manual. Does your analog clock glow? How do I turn that on?
Quote:
The backlight on clock & dial should glow when the headlights are on or if lights are on second setting (setting after auto).Originally Posted by mikemav
treacherous
close
- Join DateMar 2006
iTrader Positive Feedback0
iTrader Feedback Score(0)
- My RideG35x
Liked:95 Times in 82 Posts
Sounds like the clock light is out. I would take to dealer.
I say take it back to the dealer. As far as the brakes, I have alway thought it was one of the better brake system out there. Smooth to the feel and very effective. IF your's is not buttery smooth, take it to the dealer. Make sure you verify this on different road surfaces and at different speeds.
Mine developed the brake shudder a little later in life. I took it back to the dealer and had them resurface the rotors. Everything is great now, nice and smooth.
Quote:
+1 I thought I had a similar problem, then realized it was happening only on certain roads. After investigation, these roads have minor ripples that typically aren't felt, except when you really weight the front tires with braking.Originally Posted by Lemodular
On the clock backlight, the ring around the selector dial should light up in royal blue - if it isn't, sounds like some bulbs are out.
Thanks for all the replies! I'll bet it's that I have the headlight switch on Auto. I'll switch it to the setting after that. Will they still turn off when I exit the car (after the delay), or do I need to turn them off at the stalk this way every time?
I'll check about the brakes with the dealer when I go back next week to get a walk-through of the car's functions which we didn't have time for at delivery.
Mike,
Even on auto, when the headlights turn on, the backlights should turn on. As stated above by others, you must have some bulbs out.
Have not driven the car at night yet, so it may be they work and I didn't know. I'll turn on the lights and check it out. I assumed it would glow all the time like the dash gauges, headlights on or not. If it doesn't work I'm sure the dealer will check the bulbs.
+1 Was just in my car, can confirm that when the lights turn on (parking or headlights, auto or manual), the clock backlight and the ring around the selector dial should turn on. Note that the entire clock face lights up, and the clear ring around the dial turns royal blue.Originally Posted by longbutthair
Mike,Even on auto, when the headlights turn on, the backlights should turn on. As stated above by others, you must have some bulbs out.
Unfortunately, my car also had the steering wheel "shake" while braking at high speeds. I took it in to the dealer and they replaced the rotors. I thought it was just me, but I guess it's a little more common. Other than this minor setback, the car is great and a blast to drive.
Quote:
Should look like this with any lights on...manual or autoOriginally Posted by mikemav
Quote:
I also have the shutter. My guess is the rotors are not very high end and can't take the heat well.Originally Posted by owls94
I'm living with it until I need pads and I'll just replace them with something better at the same time.
I'm not going to bother with resurfacing as it will just happen again, only sooner now that the rotor is thinner.
