bluetooth delay on incoming calls?
Old Sep 18, 2008 | 02:22 PM
highend's Avatar
Originally Posted by AesonVirus
I had a Motorola Razr and never noticed this delay.
I just recently moved to a LG Dare and I now see this delay as well.
It's not 5 seconds long, but there is a blip between the phone ringing and answering where the system goes back to the radio, but it's only a second at most.
Hi AesonVirus,
I would like to upgrade to LG DARE as well, how did you like phone together with G35. Can you transfer all phone book date to the G? And how totally you like that phone?
Thank you.
Old Sep 18, 2008 | 11:48 PM
iandi's Avatar
I have a treo 650 & 07G35x with nav. I get a very long pause delay on outgoing calls - where I can hear the other person but they can't hear me. This can take as long as 5 seconds. Incoming calls are fine.
Old Sep 19, 2008 | 06:41 AM
AesonVirus's Avatar
The Dare has been good so far. I have an iPod Touch, love the device and really wanted the iPhone but avoided AT&T for several reasons. The phone synced super easy with the G, shows signal strength and caller id correctly and from what I can tell, sounds fine through the system.
Copying the phonebook hasn't worked for me. It kills the Bluetooth connection when I try. Maybe someone will figure out a way around these Verizon lockouts soon.
Old Sep 20, 2008 | 02:25 AM
mike_d's Avatar
I have an HTC Tilt modded out and when I get an incoming call, it rings so I push the steering wheel to answer. Shortly after I hear the caller say hello from my pocket as the radio turns back on, then a few seconds later it connects like normal. Its not really that bad, but should work like normal.
Old Sep 20, 2008 | 08:04 PM
applehj's Avatar
I updated the iPhone firmware from 2.02 to 2.1 last night, and today I had several calls, and there was no delay at all!!!
Old Sep 20, 2008 | 09:10 PM
Solid71's Avatar
I have a Iphone 3g also and have the delay. I think moto makes beter bluetooth hardware the apple or the others.
Old Sep 20, 2008 | 11:01 PM
princealyy's Avatar
Whoa .... so my non navi g35 can transfer the phone book?? or just the navigation one.. (talk about taking the thread a bit off topic, but it works )
BTW i have a blackberry 8830 with sprint, and no delay, infact i am amazed at how fast the bluetooth is on this thing, it rings and answer amazingly fast ...
Old Sep 20, 2008 | 11:03 PM
applehj's Avatar
sorta, you gotta transfer the entry one by one.
Old Sep 23, 2008 | 01:06 AM
t1328's Avatar
Hey mike_d:
Do you have navi? If so, I am very interested in how you got the Tilt to work, and what ROM you're using. I have been trying the Tilt, and I have the problem that others have described on other threads where the person on the other side can't hear me, and I hear them very garbled. The only way to fix it is to switch to the handset, and then select 'phone' to switch back, and even then, the quality is fairly poor, with folks complaining that I sound very tinny. I believe this problem only occurs in G's with the navi...
Cheers
T1328
Old Sep 23, 2008 | 01:23 AM
mike_d's Avatar
Originally Posted by t1328
Hey mike_d:
Cheers
T1328
I have the non-navi. All I did was go to comms manager, turn on bluetooth, open settings for comm manager and pair device, it works flawless except for what I described earlier. Basic operation I believe. In my settings it says...
WM 6.1 professional
ce os 5.2.19716 (build 19716.dutty's) v 6.1
then it has under the about selection...
rom version dualtouch v6 wwe
rom date 03/04/08
radio version 1.58.16.27
protocol version 25.61.30.03h
I have on here the bluetooth toggle program to save battery life, but it wont work when I click it, I have to go through comms manager.
hope that helps
Old Sep 23, 2008 | 07:19 PM
applehj's Avatar
Solid71, upgrade your firmware to 2.1. Apple has solved this problem, at least in my 1st gen iPhone.
Old Oct 29, 2008 | 09:59 PM
Solid71's Avatar
I did that but now i have a problem that the car will connect but not let the call go. I have to stop and turn the car off to clear it.
prinny
Nov 22, 2015 11:07 PM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
