bluetooth delay on incoming calls?
Old Sep 16, 2008 | 05:16 PM
applehj's Avatar
Hi, guys, I have an 07 G sedan w/o Nav, my iPhone works well with the bluetooth, except when I receives an incoming call, it takes 6~7 seconds before I can start a conversation, but once it connects, the conversation is of good quality. Is it normal? Anybody experience this?
Edit: the latest firmware 2.1 for iPhone has solved this problem for the 1st Gen iPhone that I own (very likely also applies to the 2nd Gen phone).
Old Sep 16, 2008 | 05:23 PM
jerminator's Avatar
I don't think the delay is that long in my car.
Old Sep 16, 2008 | 06:25 PM
frybecker's Avatar
I have the same issue with my iphone. When I answer the phone it flips to the radio for about 5 seconds and then back to phone mode.
It started doing this after the first software ugrade from apple.
Old Sep 16, 2008 | 08:02 PM
jazzjit23's Avatar
I don't think I have this issue, but I have noticed that even though I have programmed someone's number in the phone book, it still shows up as a private caller. Any thoughts?!
Old Sep 16, 2008 | 08:45 PM
applehj's Avatar
exactly. I have been to dealer twice, and they just say it's normal. but seems like not everybody has this issue.
Old Sep 16, 2008 | 08:52 PM
applehj's Avatar
hey jazzjit23, what phone do you have? if iPhone, what software version is it?
I think in order to have a name show up, you will have to use "transfer entry" from your phone instead of using voice command when you set up an entry. I am using a Samsung just for transfering entry. I replace my iPhone with this Samsung, transfer all the entries one by one, and replace it back to iPhone. hope this helps.
Old Sep 16, 2008 | 09:05 PM
G35Now!'s Avatar
Moderation-free
Yep - it's a compatibility issue between Bluetooth 2.0 (iPhone) and 1.x (the G). My Razor never did it, but both of my iPhones have.
Old Sep 16, 2008 | 09:08 PM
jazzjit23's Avatar
Hey applehj, I have a Samsung as well (A900M). I actually manually added these entries to the phonebook and setup a voice command for each name. When the person calls, it shows up as private but when it connects, it then shows the person's name. Any thoughts? You think if I do the phone transfer way it'll work?
Old Sep 16, 2008 | 09:41 PM
applehj's Avatar
mine is a non-Nav, so I am not sure how different is it between the Nav and nonNav. for me, when add an entry to the phonebook, I have only two options: enter the number digit by digit using voice command, or transfer from my phone. I have to use the latter in order to have the name showed.
Old Sep 16, 2008 | 09:50 PM
applehj's Avatar
Thanks, G35Now!. so seems like there is no solution. it's kinda annoying having to wait every time to answer a call. Especially think about the new phones are all bluetooth 2.0, but no way I would go back to an old phone.
Old Sep 17, 2008 | 02:41 AM
razo168's Avatar
answer the call with your phone instead of your car and you wont have that delay..
the only resolution so far =(
Old Sep 17, 2008 | 02:01 PM
herschelg123's Avatar
Me too!
+1
Same problem here. Another user posted a solution. Press answer from the phone instead of the steering wheel to eliminate this problem. My phone is usually not within reach, which is why I use the steering wheel. But I will be sure to try this new technique next time I am in the car.
Old Sep 17, 2008 | 05:18 PM
applehj's Avatar
Originally Posted by herschelg123
+1
I will try that. I usually leave my phone in the pocket when driving. it would take more than a few seconds to take it out and press the button. hopefully infiniti (or apple) can come up with some solution soon.
Old Sep 17, 2008 | 08:19 PM
AesonVirus's Avatar
I had a Motorola Razr and never noticed this delay.
I just recently moved to a LG Dare and I now see this delay as well.
It's not 5 seconds long, but there is a blip between the phone ringing and answering where the system goes back to the radio, but it's only a second at most.
Old Sep 17, 2008 | 08:25 PM
MiniRX7's Avatar
Happens to me on my HTC Tytn2 running custom ROM... i answer via phone and its a lot less delay
