Rattles
Old Nov 11, 2008 | 12:52 AM
CART's Avatar
Rattles
I know that this has been talked to death already, but I am getting alot of "cracking noise" coming from the dashboard mostly when I accelerate hard of when I turn the heat on when it's cold out. It doesn't seem to be related to the road conditions.
The car is only 1 week old about 1,000 miles. Didn't hear it when I bought it, but it wasn't very cold out either. Normal?
(Otherwise I love the car!)
Thanks!
Old Nov 11, 2008 | 01:26 AM
Csquared's Avatar
Yeah weather been cold and i'm hearing it from up there too but only when i go over a bump so no idea.
Old Nov 11, 2008 | 06:11 AM
renok7's Avatar
In my case the cowl at the bottom of the windshield was rubbing against it. From the outside I sprayed WD40 between the base of the windshield and the cowl and... no more noises.
Old Nov 11, 2008 | 07:18 AM
CART's Avatar
It seems to be a noise that is totally random. Sounds like the plastic is expanding or contracting.
Old Nov 11, 2008 | 09:30 AM
kool_yaar's Avatar
^+1 i usually press on it once and it does not happn during the rest of the trip
Old Nov 11, 2008 | 11:06 AM
DanGarion's Avatar
I seem to be having a rattle up in the moonroof area, because I usually drive with the cover open and the roof closed, if I close the cover I don't hear the sound. I'm wondering if I should take it to the dealer to resolve it...
Old Nov 11, 2008 | 11:45 AM
kool_yaar's Avatar
you should if the dealer is close and you have time, always good to have such complains documented atleast...
Old Nov 11, 2008 | 03:04 PM
gugarci's Avatar
I have that cracking sound for the dash also. Doesn't happen all the time either. Sometimes it makes the cracking sound while the car is perfectly still.
Old Nov 11, 2008 | 04:15 PM
ugaexploder's Avatar
welcome to owning a nissan
Old Nov 11, 2008 | 06:01 PM
CART's Avatar
Mine too (even when standing still), I'm afraid of what will happen when it gets really cold.
Old Nov 12, 2008 | 08:00 AM
gugarci's Avatar
I wouldn't worry too much about some of these noises. A lot of them will disappear as the car ages and the body trim parts settle in. But I could be wrong.
Old Nov 12, 2008 | 12:31 PM
C5TOG35's Avatar
Thanks!
My 07 has been at the dealer for almost a week with the same issue. They stealership was unable to find the noise and tried to blame my non OEM windshield. Which is funny considering I have been complaining about this issue prior to having my windshield replaced. They have finally isolated the noise to the dash/cowl. I will post and update shortly.
Old Nov 13, 2008 | 06:12 AM
renok7's Avatar
Tell them to simply squirt WD40 between the base of the windshield and the cowl.
TNRocker
Sep 21, 2015 08:36 AM
socaldavid
Sep 5, 2015 04:35 AM
nickmcc123
Aug 20, 2015 03:10 PM
kinetek
Aug 3, 2015 04:25 PM
