need some performance advice
Old Dec 4, 2008 | 04:44 PM
ovrkast's Avatar
Living here in the mountains and 4,500ft. above sea level, I notice that my 2008 G35x sedan doesn't perform well compared to when I'm down in southern Cali. There seems to be a lag issue. I understand that at sea level, there is more air for the vehicle to breath and that is why my car seems to perform better down there.
Is there anything I can do (not too drastic or expensive) that will help alleviate some of this sluggishness, and make it perform close or equal to as if it were at sea level?
Old Dec 4, 2008 | 04:50 PM
Texasscout's Avatar
Barometric pressure is the problem. Your ECU is compensating for the lack of it by reducing the mixture, thus less power. No, not a lot you can do. Try some breathing mods (pop charger, CAI). If that doesn't work, it's FI.
Old Dec 4, 2008 | 04:53 PM
ttrank's Avatar
Grocery getter
Boost will make a big difference but go turbo not supercharger! Stay away from supercharger kits up at that altitude. Supercharger kits build a set amount of boost at sea level and a lot less at that altitude. You would have to do some sort of a custom pulley setup to get more boost up there. I had a stillen supercharger that would build ~8.5psi in Phoenix (1100ft) and ~5psi in Prescott (5300ft). My TT kit makes the same boost no matter where I am at.
ovrkast's Avatar
So it looks like I'm screwed unless I'm willing to fork up some major cash for upgrades or move to sea level?
Old Dec 4, 2008 | 05:20 PM
fecurtis's Avatar
Yup.
Old Dec 4, 2008 | 05:24 PM
ugaexploder's Avatar
it would be cool if you dropped the M45 8-cylinder in your sedan
ttrank's Avatar
Grocery getter
The good news is that all other N/A cars up there have the same problem so you are all equally slower.
Old Dec 4, 2008 | 05:27 PM
express705's Avatar
or equally faster
Old Dec 4, 2008 | 06:09 PM
sredish's Avatar
only $29 on ebay.
ECharger
Dyno:
Old Dec 4, 2008 | 06:35 PM
AesonVirus's Avatar
LOL..... you first!
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Rose M
Oct 12, 2015 10:00 AM
6spdGspot
Oct 5, 2015 01:55 PM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
