Which Mod???
Old Jan 13, 2009 | 11:22 AM
joex420's Avatar
Which Mod???
I just need opinions on which mod I should get, I will take all and any opinions. I have 300$ to spend, i'm thinking of midnight grille, gt spec frunt strut, exhaust tips, something with brakes. I'm not looking to do anything to exterior but I will consider the grille. And the intake I will do after 3 more years at least. Thanks in advanced
Old Jan 13, 2009 | 11:41 AM
5u30five's Avatar
do the intake now to compliment your magnaflow. you can always just paint your grille black if money is tight. gl on your choice.
Old Jan 13, 2009 | 03:26 PM
ugaexploder's Avatar
well, the grille i would just get painted at a local paint shop...it's a really simple process and personally i wouldn't want to pay too much for a new grille since it's a replacement mod...i would go for the gt spec strut bar because it's an addition part...you can't do much with $300 to the brakes unless you want to buy stainless steel brake lines...personally i'd go with intake before a strut bar though...i dunno why you want to wait 3 more years before you put on an intake either
Old Jan 13, 2009 | 03:54 PM
TheIvoryG's Avatar
I personally don't like the midnight grille. Anything with brakes would cost you more than $300(because in my mind BBK is the only next option for brakes). Tips would compliment your exhaust nicely and is a simple mod. Strut I haven't seen enough response on to know if its worth it or not yet, but that would be high on my list for sure. Intake would be another consideration because that with your exhaust would be hot.
Why not a front lip? That would be my #1 if I were you...
Old Jan 13, 2009 | 03:56 PM
joex420's Avatar
Well I wanted to wait till my 4 years of warranty, I already had my car for one. I want to make sure I can put almost everything back stock just in case if i'm going to sell this car later on so painting the girll would be harder to reverse then getting a new one where I can switch them. I've already got my eyes set on K & N intake but thats coming later. Does the front strut gt spec do much with the steering and does clear the hood space?
Old Jan 13, 2009 | 03:59 PM
oh i see...the intake shouldn't void the warranty but if you're on the fence then don't do it...also, the midnight grille is technically a stock item so if you paint yours, the difference will be negligible. i was going to put my strut bar on this morning but couldn't find a 10mm socket...it does clear the hood space from what i've read...i can get back to you on this later on this week tho
Charchar66
Dec 19, 2019 01:17 PM
Video Share
Jan 31, 2017 04:00 PM
g.spot
May 9, 2016 10:54 PM
prinny
Nov 22, 2015 11:07 PM
RWDguy4238
Sep 30, 2015 12:13 AM
