My car wouldn't lock when I was driving
Old Jan 26, 2009 | 03:56 AM
NewGuyG35's Avatar
So I hop in the G and the lock buttons were not responding when I try to lock or unlock. It was like this throughout the trip. I did lock the car with the remote key but the buttons still wouldn't respond. After I reached my destination and turned off the car, the lock buttons were working perfectly fine. Has this happened to anyone else.
Old Jan 26, 2009 | 08:05 AM
AesonVirus's Avatar
Dumb question, I know, but were all of the doors completely shut? I've seen that cause the locks to not function and the only alert you get is the little "!" light.
Old Jan 26, 2009 | 01:09 PM
PeterUbers's Avatar
Sounds like an issue with your BCM -- during the period when the locks were not working, did you hear the relay "clicks" with the lock and unlock buttons depressed? If not, then it's your BCM likely -- in the passenger kickpanel ..
If you dont' recall the clicks .. perhaps it's a problem closer to the lock motors .. however, there are four lock motors (obv. one at each door), and only one lock relay (i learned this after extensive time at the BCM installing KP's autolock module)... would probably be quick to blame that relay before blaming anything else.
I would ask you to check fuses... but it started working again and that would be unheard of it a fuse blew.
Old Jan 26, 2009 | 01:57 PM
PR G35S's Avatar
This has happened to me a couple of times...Turn the car off, turn it back on...works fine...
Old Jan 26, 2009 | 04:34 PM
NewGuyG35's Avatar
It works fine now. That was weird.
Old Jan 27, 2009 | 02:40 PM
nr2d's Avatar
This happened to me this past Friday night. Had to unlock the door manually. The car locked OK with the Key FOB. When I got back into the car to head home it worked fine.
Old Jan 27, 2009 | 11:14 PM
ern_dizzle's Avatar
this has happened to me twice... the first time it happened i was really worried cuz i thought i wouldn't be able to lock my car. But then the second time it happened, i just turned the car off, and then on again. It was really strange!!
Old Jun 22, 2009 | 09:24 PM
ccalimquim's Avatar
Question: Do you know where the Lock relay is located?
Old Jun 23, 2009 | 06:30 PM
jsmonet's Avatar
this happens to me as well.
how many of you have installed/had someone install factory illuminated kick plates?
chinee
Jun 10, 2024 07:48 PM
mike730
Jan 12, 2018 04:25 PM
apintojr
Jul 23, 2015 10:52 AM
realtalk21
Jul 20, 2015 09:07 AM
whattf
Jul 17, 2015 02:41 PM
