How much your dealer charge for labor, 30, 45, 60K service?
Old Apr 13, 2009 | 09:07 PM
njchen24's Avatar
Greetings:
I am planning on getting a G37x this year (Oct/Nov timeframe) if the price is right (hoping for under $33K). Before making the plunge, I wonder how much your dealer charge you for labor, 30K, 45K and 60K service.
Thanks in advance for your time.
Old Apr 13, 2009 | 09:13 PM
tailwindK's Avatar
For the 30k the dealer quoted me $895. I have heard bt $650-900. I did most of the work myself and saved myself around $600. You can look up the service manuel and see what things need to be done. Their charge is ridiculous IMO. Hope that helps.
Old Apr 13, 2009 | 09:20 PM
njchen24's Avatar
Thanks for your response.
I don't have the car yet so I can't look at the manual. Is there someone kind enough to give me an idea what is the manufacture recommendation for 30K?
Old Apr 13, 2009 | 10:21 PM
baileyt35's Avatar
For 30k my dealer is asking $480, dealer where I purchased the car in Atlanta, GA is asking $595.
Old Apr 13, 2009 | 11:14 PM
tailwindK's Avatar
1. Replace engine oil and filter
2. Lubricate all locks and hinges
3. Replace transmission fluid
4. Replace differential oil
5. Replace engine air filter
6. Replace wiper blade refills
7. Replace AC microfilter
8. Replace engine coolant
9. Replace radiator cap
10. Replace engine drive belts
11. Inspect AC system
12. Inspect all lights
13. Inspect transmission fluid
14. Inspect axel and suspension
15. Inspect brake lines and cables
16. Inspect brake system
17. Inspect cruise control vacuum hoses
18. Inspect driveshaft boots
19. Inspect exhaust system
20. Inspect ball joints
21. Inspect steering gear and linkage
Also, if you go to a Nissan dealership they are usually much less espensive compared to infiniti.
Old Apr 14, 2009 | 08:33 PM
harley01's Avatar
When I bought my car new I only wanted to have an Infiniti dealer doing the work. Then I changed the in cabin filter myself and started to understand what a ripoff they can be. I have a mechanic I've know for years and now he does all the work for a lot less. I did like the loaner car program at the dealer, but even that is no longer available.
Old Nov 16, 2009 | 02:55 AM
ultraman1017's Avatar
http://www.beshoffinfiniti.com/service-menu-g35-08.htm
Old Nov 16, 2009 | 11:28 AM
Rutland's Avatar
What dealer did you get it done for 480 and which Atlanta dealer is asking 595?
Thanks!!
Old Nov 17, 2009 | 04:04 AM
Bahg35's Avatar
Guys, you pay so much for your service I don't know why!!
From my experience in my country located in the GCC, we service our cars each 5,000 Kilometers.
I will start with 20,000 I paid: 53 USD
25,000: 92 USD
30,000: 160 USD
I paid I think 50 bucks more for removing my Stillen Gen3 intake and installing the OEM ones. They had to clean out the Throttle body which was a warranty issue. But they couldn't do it with the after market intake on it.
My last service was 35,000 I paid 106 USD. This was done last week.
All my services were for general things such as oil, filter change and cleaning out the break discs and pads, nothing major was done for the car, just replacing the ordinary stuff.
Old Nov 17, 2009 | 07:01 AM
joek19522's Avatar
I'm located in the Lehigh Valley in PA. I was quoted $485 for the 30K service.
Old Nov 17, 2009 | 02:35 PM
redgreen's Avatar
A crazy $820 for a "standard" 30k service in Portland, Or. After looking it over they wanted to do a bunch of stuff that was not recommended or needed. After picking it apart and reducing to the Infiniti factory recommended services, it was reduced down to around $400, but then I did the cabin filter and air cleaners. So about $460 after I was done. They did zing me by printing the receipt saying I had turned down the 30k service. Wanted the receipt for when I resell it to show it was properly maintained. Oh well it still shows everything that was done.
Old Nov 18, 2009 | 11:30 AM
dohturdima's Avatar
The outrageous dealer labor costs and charges for "services" like inspecting this or that (which I doubt is done at all) are the reasons I do most of the filter changes myself and have the ATF/flush/brakes/oil changes done by a local mechanic. I only do warranty repairs at the dealer.
Old Nov 18, 2009 | 04:12 PM
Austin713's Avatar
transmission and diff change at 30k? yay or nay?? i checked my coolant and it is still bright green!! im at about 37k miles so im a bit past the 30 k mark lol. all the other cars i had owned reccomended those at 60k miles and i drive mostly highway as well.
Old Dec 3, 2009 | 12:33 AM
Rottten Appples's Avatar
DIY FTW!!! just what i was asking myself today haha wow..
Thebaws11
Jul 2, 2021 11:36 AM
infinitiway
Aug 8, 2017 12:38 PM
Detailed Image
Sep 4, 2015 08:35 AM
