Dash vinyl/rubber warping
Old Jun 3, 2009 | 07:47 PM
  #31
baileyt35's Avatar
Originally Posted by Austin713
Mine is going in tomorrow morning for the heated seats TSB and the Weatherstripping TSB i am going to try and get them to fix it for me. ill let you know what they say. west houston has been pretty good to me, i complained about the peeling steering wheel. and door issue and they gave me a brand new steering wheel and door panel!!
What is the TSB on the heated seats about? What weatherstripping? Is it the rubber around the doors?
Old Jun 3, 2009 | 09:00 PM
  #32
NationsMostWanted's Avatar
Originally Posted by J2S2M
I had the same issues in my 08. Had the edges on both sides start to peel and lift up. The loose piece would rub up against the other part of the dash and started making these annoying squeaks. So I had the dealership replace the piece under warranty. However after about 5 months, the problem occurred again, so I had to replace it for the 2nd time under warranty. The service tech told me that it is a design flaw for using cheap material and that there isn't much I can do other than hope that it doesn't happen again.
I am VERY disappointed with the interior quality of the G. *sigh*
Hmm so technically we can keep going back even after warranty to get it fixed as long as u stay withinh the 12 month service warranty forever
Old Jun 3, 2009 | 09:36 PM
  #33
J2S2M's Avatar
I dont think they would fix it for free if my factory warranty expired.
Old Jun 3, 2009 | 09:39 PM
  #34
no they wont but listen to this...if you get it fixed before the factory warranty end you should get a 12 month regular warranty as if your a regular customer. if the dash peels again before the 12 months is over technically you get it fixed under repiar warranty...you can keep doing this over and over if its under 12 months, 12k miles.
we live in CA if theres a known issue or defect they need to find an update or something to fix this not cover it up till factory warranty is over.
Old Jun 3, 2009 | 09:43 PM
  #35
im pissed they messed up two other things while fixing this for me
Old Jun 3, 2009 | 09:59 PM
  #36
J2S2M's Avatar
Yea. They left some scratches on my guage cluster cover and left a load of messy residue from the cheap dressing/protectant that they use.
Them BlTCHES.
Old Jun 3, 2009 | 10:22 PM
  #37
Yea they says they order me parts to fix in 10 days if not I'll be making a big deal
Old Jun 4, 2009 | 09:42 AM
  #38
Austin713's Avatar
its on 07 sedans. basically there is a faulty harness that causes the passenger heated seat to be much hotter than the drivers side. it also makes the Hi and Lo setting feel like there is no difference between the two. I know its summer but i just decided to get it fixed while i had it in.
the weather stripping is around the driver side door, it has come unseated (infiniti doesnt seal it down in the valley with anything) the fix is to put 3m tape in there and seal it down in there.
Old Jun 4, 2009 | 05:41 PM
  #39
baileyt35's Avatar
Thank you, I will definitely be having this done! Got any TSB numbers?
Old Sep 10, 2009 | 02:11 PM
  #40
shawnost's Avatar
Thumbs down
So I took my car into the local dealer here in NY and they repaired the warped dash part for me under warranty. However while they were doing the repair they managed to scratch the trim piece on the steering wheel behind the horn/airbag. When I notified the service manager at the dealership I was told that since I could not prove that the damage was caused during the repair that he will not replace the damaged part and will only have someone come and attempt to "patch" or "repair" the cosmetic damage. WTF??
So I called Infiniti consumer affairs and they were all but useless in resolving the issue. Damn, I am just so pissed right now!
Old Sep 11, 2009 | 12:59 AM
  #41
consumer affairs should be able to help u....
Old Sep 14, 2009 | 01:40 PM
  #42
shawnost's Avatar
No help from them. They basically called the service manager on my behalf but could not get them to budge. After a few complaints to the GM of the dealership and the dealership chain I have been told that if the "fix" they will attempt later this week is not to my liking that they will pursue "other" means to remedy the situation. I guess we'll see.
Old Sep 14, 2009 | 04:05 PM
  #43
ChrisG35Driver's Avatar
For anyone that has had this replaced under the warranty, can you do the rest of us a HUGE favor and copy and post your receipt as an attachment so we can take it in to the dealers that are trying to deny the work?????
Thanks!
Old Sep 14, 2009 | 08:36 PM
  #44
g37musings's Avatar
As long as it is under warranty, make them replace it.
Old Sep 14, 2009 | 10:22 PM
  #45
G35power's Avatar
They replaced one on passanger door, it looks like G37 part(plastic)!!! Next time i will tell them to replace other ones. If anybody need the new part ## i can post it from my invoice!!!
