Big Problem
Old Aug 29, 2009 | 12:38 PM
  #31
Q8y_drifter's Avatar
is front and rear toe angle supposed to be 0? (or as close to that as possible?). I know for a fact that -1 degree of toe-in in the back adds a lot of straight line stability. especially when you accelerate hard from a stop.
Old Aug 29, 2009 | 01:22 PM
  #32
Cabad85's Avatar
see link -->toe, caster and camber
Old Aug 29, 2009 | 02:01 PM
  #33
Toe can also be measured in degrees. I race R/C models and we measure camber, caster toe, ackerman, etc. all in degrees. Anyhow, camber is not the only suspension adjustment that can be used to increase (or possibly decrease) stability. We use 1 degree of toe-in in the rear to increase straight line stability. Sometimes as much as 2 or 3 degrees are used depending on track surface, tires, type of model, etc.
Drifter2090
Dec 26, 2015 12:10 AM
Mick_L
Aug 25, 2015 04:27 PM
Phenomenon9
Aug 9, 2015 01:34 AM
