New Rims and Tires - Suggestions Please
Old Jun 12, 2009 | 11:02 AM
CGY-G35x's Avatar
Question New Rims and Tires - Suggestions Please
I want to but new summer rims for my 07 G35x and was thinking of the following rim:
http://www.tirerack.com/wheels/Wheel...7&autoModClar=
I'm not sure if the link will work but it is the 18X8" Xline Energy by Oz with the following details:
Offset: 45mm
Backspacing: 6.29"
Bolt Pattern: 5-114
Weight: 26.8lbs.
Tirerack recommends a Tire Size of: 225/50-18
Is this a decent rim? Is the tire recomendation what I should stick with? Can anyone make some suggestions of some tire brands and sizes I could look into?
Thanks in advance,
CGY-G35x
Old Jun 12, 2009 | 11:16 AM
Gu3s5who's Avatar
no offense but you could do better than those...
Old Jun 12, 2009 | 11:19 AM
CGY-G35x's Avatar
If you make some suggestions...I'd be happy to look at them.
Old Jun 12, 2009 | 03:12 PM
madmax2k1's Avatar
These look good:
http://www.tirerack.com/wheels/Wheel...All&sort=Brand
Old Jun 12, 2009 | 04:11 PM
MojoKidd's Avatar
Offset: 45mm
Backspacing: 6.29"
Bolt Pattern: 5-114
Weight: 26.8lbs.
Thanks in advance,
CGY-G35x
A tire size of 225/50-R18 is going to severly limit your tire selection. If you step up to a 245/45-R18 you'll get a lot more choices. You can safely go with 45mm offset 18x8.5" on all four corners.
vitamin.v
Nov 7, 2019 06:10 PM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
paolojericho11
Sep 11, 2015 07:08 AM
Gip
Aug 24, 2015 05:31 PM
JaeXL
Aug 4, 2015 07:43 AM
