Replacing battery on intelligent key.
Old Nov 4, 2009 | 08:12 PM
ThatsMyG's Avatar
1) My car started fine this evening, but I saw an LCD warning that I never saw before - picture of a key, and what looked like a Full/Empty gauge. I assume this means low battery - correct? I did not notice or look for any light near the key "port" area.
2) I could not find the picture in the manual - is it there?? Why couldn't they just say 'low battery on i-key" ?????
3) I had the key replaced a year ago when they recalled the keys for the cell phone issue. Shouldn't they last a little longer??
4) I assume all I need to do is replace the battery (CR2032). I will hold onto my spare key until I do so, just in case. I am having some trouble though cracking the case open. Any tricks? other than what is says in the manual ( which is to remove the manual key, insert a screw driver and twist).
Thanks
Old Nov 4, 2009 | 08:58 PM
bmovie's Avatar
My brother inlaw had the same thing happen...he has an 08 G35xS....I wonder does my 07 do this as well?
We we're both wondering what that meant.....And I think you're correct to assume that your battery is low on the KEY FOB.
Old Nov 4, 2009 | 11:07 PM
bat6wc's Avatar
the case pops right open. try from the bottom
Old Nov 4, 2009 | 11:19 PM
G35Now!'s Avatar
Moderation-free
Thanks
1. Yes
2. Nissan will undoubtedly welcome your input
3. A year for a bluetooth key that never leaves your pocket doesn't seem too terrible to me - I've replaced mine about annually since buying the G
4. Take out the metal key, then put a knife blade in-between the halves to "pop" it open (long ways, not just the point). Pretty easy. Replacement takes about 30 seconds.
Old Nov 5, 2009 | 12:05 AM
SVLRx's Avatar
Both my G's key had to be replaced after ~2.5 years. So i guess a little more than 1 year for each key. Buy the twin pack of 2032 batteries, cheaper than buying 1.
Old Nov 5, 2009 | 02:10 AM
tg1234's Avatar
The life of the battery depends on soo many things. I have a spare key needed new battery 2 times. I don't even use it. My #1 key still on the iriginal battery.
I keep my spare key in the garage right beside my G. I guess it communicates to the car.
Also the warning shows how much battery life left in the fob. Don't have to replace it right away.
Old Nov 5, 2009 | 01:31 PM
terrycs's Avatar
Originally Posted by tg1234
...Also the warning shows how much battery life left in the fob. Don't have to replace it right away.
I have a feeling that "gauge" is only an icon and does not really show remaining power.
It's only a couple bucks ... just change as soon as it is convenient. No need to try and get every last drop of power out of the battery!
Old Nov 5, 2009 | 08:39 PM
tg1234's Avatar
I think it does work as a meter. I don't use that key much but I believe it looked different few months ago I saw the sign.
You can use the battery its not like you'll be stranded in the midlle of nowhere. You can just put the keyfob in the slot when it is dead and it is still functional.
But I agree the battery is cheap. I keep one at the garage and one in the glove comp.
Old Nov 6, 2009 | 10:02 AM
terrycs's Avatar
I'd be curious to learn if it is really a gauge or if it is an icon. Post up your results if you run that ikey down some more.
Old Nov 6, 2009 | 10:39 AM
tg1234's Avatar
I think mione is almost dead. I'll take a picture today and see if somebody can compare. Bt I am sure to remember to see the icon almost full and lesser few months later. I might just be on crack or something. LOL Hope not.
Old Nov 6, 2009 | 11:26 AM
tg1234's Avatar
Ok I took picture of the one I have right now.
Anybody seen it other way around with more full? Hope my memory did not fail me. LOL
Old Nov 6, 2009 | 11:44 AM
douglas555's Avatar
Mine looks exactly the same as your picture. You should wear your seat belt.
Old Nov 6, 2009 | 12:11 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
that's the only one that I recall seeing
Old Nov 6, 2009 | 01:24 PM
tg1234's Avatar
Oh boy than I am officially stupid. LOL
Sorry Terry you were right
I was wrong. Now I feel like him.
Old Nov 6, 2009 | 05:27 PM
ThatsMyG's Avatar
I got the same. Clearly its an icon, not a guage
