Would These Wheels be a bad Idea on an X?
Old Nov 24, 2009 | 01:22 AM
TallyG's Avatar
Question Would These Wheels be a bad Idea on an X?
20x8.5 +40,
2" lip
Nitto Invo tires 245/35/20
20x10 +40
5" lip
Nitto Invo tires 275/30/20
help me guys i am clueless when it comes to wheels.
Old Nov 24, 2009 | 01:59 AM
nghiars's Avatar
exact tires i would run on that set up.
Old Nov 24, 2009 | 03:34 AM
TallyG's Avatar
i was thinking maybe there would be problems long run since my car is AWD.
Old Nov 24, 2009 | 08:02 AM
sunny G-35 NYC's Avatar
From what I know you are within 3% rolling diameter with the specs you posted then you will be fine. I have never tested this 3% claim because I got 20x9.0 all 4 corners. Maybe you can try it and validate this claim, but I have seen people run staggared wheels with no problems to the Awd system.
Old Nov 24, 2009 | 08:03 AM
WhAt wheels are these anyway?
Old Nov 24, 2009 | 08:45 AM
TallyG's Avatar
http://www.hpdesignwheels.com/wheels.html
the Flight Design.
Old Nov 24, 2009 | 09:46 AM
Did you check the marketplace to see If one of the website vendors have these.
And please don't take offence but you can do much better than those wheels. Pm me and let me know how much you want to spend on wheels and tires and I'll show you a couple of designs and good wheel manufacturers and company you can buy from.
Old Nov 24, 2009 | 09:58 AM
suby01's Avatar
the AWD should have same size tires and wheels both front and back. this will throw off your traction and may damage your car.
Old Nov 25, 2009 | 01:53 PM
TallyG's Avatar
I am getting them for $1000 slightly used, i am a low baller so i think the price is pretty decent.
Old Nov 25, 2009 | 02:59 PM
rpm&my_G35's Avatar
You probably shouldn't put THIS staggered setup on your G. According to the calculator there is >20mm difference in the circumference.
My mechanic always reminds me to rotate my wheels often (which I do myself) to keep them the same diameter. It's very important on an AWD or 4WD system.
Last edited by rpm&my_G35; Nov 26, 2009 at 09:44 AM. Reason: replaced dia. with circ.
Old Nov 25, 2009 | 05:17 PM
greg_atlanta's Avatar
2008 G35 Journey Sedan no sunroof
= slightly bent?
Old Nov 25, 2009 | 10:41 PM
bat6wc's Avatar
for the Invos....
Old Nov 26, 2009 | 05:09 AM
TallyG's Avatar
Thumbs up
Originally Posted by rpm&my_G35
You probably shouldn't put THIS staggered setup on your G. According to the calculator there is >20mm difference in the diameter.
Attachment 114126
Wow thanks rpm&my_G35, Thats actually really helpful info. I am not getting the rims now, i feel bad now because i feel like i kinda dragged the guy along but i def dont want to damage my car.
so what kind of staggered rims would i be able to buy for the X? You wont believe how frustrated I got when i found out that the Q300 Invidia Exhaust wont even fit the G35X. That wouldve been a good alternative to getting rims, but i guess not much out there for our X. Its funny in the Tri-State area 8 out of 10 Gs I see are X.
Thanks for the Help. Any further recomendations?
Old Nov 26, 2009 | 08:26 AM
soundmike's Avatar
Attachment 114126
Are you sure? 20mm isn't that much, as your calculator shows it's less than 1% difference between front and back.
TallyG, it's not so much your wheels, but the tire size.
Old Nov 26, 2009 | 08:41 AM
kregg's Avatar
yeah its 20mm difference in circumference 3mm difference in radius (or diameter) either was yeah its all 1%.
