Isthis normal or a problem
Old Dec 12, 2009 | 12:27 PM
mike3000's Avatar
Today I had to brake hard and turn the wheel at the same time....While doing so the car appeared to downshift multiple gears and the revs went way high and stayed that way for about 10 seconds, almost as though I had the car in manual mode and downshifted one gear to many. Please let me know if this is normal behavior.
Old Dec 12, 2009 | 12:46 PM
jkh296's Avatar
Were you driving in DS mode? This sounds like DS mode behavior.
Old Dec 12, 2009 | 12:51 PM
mike3000's Avatar
I wasn't in DS mode, that's the weird part
Old Dec 12, 2009 | 01:15 PM
lefizzet's Avatar
What did you do during those 10 seconds? If you bliped the throttle for a second it should have shifted to the correct gear.
Old Dec 12, 2009 | 03:55 PM
tg1234's Avatar
Was it for 10 seconds or maybe it felt 10 seconds? Our G is equiped with rev match downshifting and if you drive it somewhat spirtited you can feel the car downshifts for you and revs up the car. Mostly you can feel it in DS mode buty in some occasion you can feel it in D also. It is possible it was downshifting few gears since it wasn't sure what speed you'll end up at.
I say it is normal but the 10 second sou nds a little too much. If you were slowing down in that 10 seconds sure. But you were already stopped than not normal.
Did you stop to 0 or just hard slow down to a certain speed?
Old Dec 12, 2009 | 04:11 PM
lefizzet's Avatar
^ Good point. By 10 seconds you probably mean 2-3 where revs were past 5-6k. If so this has happened to me before.
Old Dec 12, 2009 | 05:42 PM
IvoryPearl07G's Avatar
it has happened to me as well. in my mind i see it as an assist to the braking by using the engine to slow the car down as well. also by having the car in a high gear allows you to snap back on the throttle and escape a potentially hairy situation without waiting on the tranny to get ya into the gear it needs to be in to accelerate. simply an engineering thing that i like.
Old Dec 12, 2009 | 11:32 PM
mike3000's Avatar
it felt like 10 seconds, realistically it was probably 2, maybe 3
Old Dec 13, 2009 | 08:30 AM
tg1234's Avatar
Yeah that just the rev matching downshift. Sometimes you feel it more than other times. It more active in DS and when you drive it hard.
Old Dec 13, 2009 | 01:57 PM
g37musings's Avatar
I would say normal, mine has done it when I am braking hard and turning. First time it did it, it freaked me out. But now it does it consistently at the some location approaching my house, but only when I am on the brakes hard.
Old Dec 14, 2009 | 12:23 PM
4drsleeper's Avatar
Now that's a pretty smart car...using higher revs to help slow down the car when you hit the brakes hard. I'm impressed.
Old Dec 15, 2009 | 05:52 PM
Glover997's Avatar
nothing to worry about man . . it's way normal !
chinee
Jun 10, 2024 07:48 PM
wonderizm
Sep 24, 2015 03:09 AM
zcherub
Aug 30, 2015 05:04 PM
G35CO
Aug 25, 2015 02:00 PM
Phenomenon9
Aug 9, 2015 01:34 AM
