Stopping Runaway Cars: Our Brake Technology
Old 02-05-2010 | 01:51 PM
herschelg123's Avatar
In the new Car and Driver, there is an article about runaway cars, based mostly on the current problems with Toyotas. In order to demonstrate how to stop a car with a stuck accelerator, they compared a Toyota Camry to a brand new Infiniti G37 Convertible.
In doing so, they revealed two pieces of technology that I did not know existed. My question is this: do older G35 (2007+) cars have the following abilities?
1. Car and Driver writes, "many automakers have added software to program the throttle to close--and therefore cut power--when the brakes are applied." Does a 2007 G35S have this technology, or is it only the new cars?
2. Car and Driver writes, "...whereas the Infiniti kills the engine after three rapid-fire presses." This in regards to the push button Start mechanism--the idea is that Infiniti will allow you to stop the engine if you push the start button three times in a row. Toyota does not offer this, but clearly, a new Infiniti does. Again, is this true in a 2007 G35S?
I will admit, I did not read my owner's manual from cover to cover, but I do not remember a section on stopping runaway cars. The triple button press is a good thing to know, and hopefully, some of the older Infiniti models have this technology.
I hope nobody will ever need to do this to their car, but at least it was useful information.
Old 02-05-2010 | 02:15 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
wow... great plug for Infiniti to be used in the comparison to Toyota.
...IDK for sure but I would imagine this change started when Infiniti went to the pushbutton start.
It should be easy enough to test.
Old 02-05-2010 | 02:16 PM
Austin713's Avatar
I know that when i have tried to do a brakestand before to get the engine to rev up before launch it didnt like it at all. as soon as i got on the gas with the brake on the engine bogged down... i dunno maybe i just wasnt pressing the gas hard enough..
Old 02-05-2010 | 02:29 PM
nghiars's Avatar
i thought i read somewhere that toyota's could be turned off if you held down the push start/stop button... Can anyone confirm/invalidate this?
Old 02-05-2010 | 02:30 PM
nghiars's Avatar
Was your VDC on?
Old 02-05-2010 | 02:36 PM
thescreensavers's Avatar
Mr.202?
Yes they can but, it takes longer then what the Infiniti does it in.
tbh, ask someone on the street or even your non car friends, what do you do if that problem happens, 99% of the time they dont have a clue.
Old 02-05-2010 | 03:00 PM
Glex25's Avatar
Administrator
G35 have had the fuel cut off when pressing the brake pedal for awhile that is why we can't do stand still burn outs
As far the push start i have not seen that personally
Old 02-05-2010 | 03:10 PM
Mr.202?
^ I thought it was the ABS or VDC systems that stopped burnouts. And you had to pull the fuses to them to do burnouts.
Old 02-05-2010 | 03:14 PM
elayman's Avatar
on non-push button cars cant you just shut the car off via the key when its running? or at least shift it into neutral so it stops accelerating
Old 02-05-2010 | 04:07 PM
soakgame's Avatar
i want to try the 3 rapid fire press.. just have to find a safe place to do it
Old 02-05-2010 | 04:08 PM
Mr.202?
^ just go 5mph in a parking lot lol.
Old 02-05-2010 | 04:21 PM
tg1234's Avatar
Yes the G35 has it all. +1 for Nissan/ Infiniti for being smart about brake over ride. Also as mentioned you can just hold the push bottom or hit it 2 or 3 times.
But I think Toyota/ Lexus has this just they have to hold the bottom longer. Could be wrong tho.
IvoryPearl07G's Avatar
every drive by wire nissan/infiniti drops the throttle to 25% when the throttle and brake are pressed.
and yes my car cuts the motor when rapidly hitting the start button 3 times.
Old 02-05-2010 | 04:42 PM
B L U E S L A T E's Avatar
Honda Accord
Press the Engine Start button 3 times will kill the ignition. I know cuz I tried. lmao
Old 02-05-2010 | 04:57 PM
terrycs's Avatar
A lot of people thought I was crazy for doing this a few years ago:
https://g35driver.com/forums/g35-sed...car-drive.html
