Upper control arms AWD & RWD same???
Old Mar 7, 2010 | 12:07 AM
Shurik355's Avatar
Hey guys can someone let me know if upper control arms in AWD & RWD models are the same or different?? should be the same I'm thinking but who knows. Just need to make sure.
thanks in advance guys!
Old Apr 29, 2014 | 01:04 PM
yosip1115's Avatar
This thread deserves to be answered. There is misleading information in the AWD common info thread stating that aftermarket options for upper control arms are available for the X but there are none listed... Nobody has answered the question if you can bolt up RWD aftermarket upper control arms onto an AWD G. I cannot be the guinea pig this time around like I usually am...
Old Apr 29, 2014 | 09:26 PM
Shurik355's Avatar
Wow this is my OLD thread, back in the day! Can't believe myself that it didn't ever get answered.
Old Mar 5, 2018 | 09:51 PM
MacSpeedy's Avatar
ill be the guinea pig and find out if they are compatible this weekend...ill keep this thread updated
Old Mar 6, 2018 | 10:25 AM
yosip1115's Avatar
I tried it!!
So... The awd g comes 1" higher than the rwd. The camber arms reflect that.
Running rwd a arms kicks the camber positive 1 degree or so on an x.
It brought my camber back into spec even though I was lowered. Saved me a bunch of $
Old Mar 6, 2018 | 10:44 AM
MacSpeedy's Avatar
I have a RWD and recently picked up an AWD Upper control arms, I'm not lowered although I have a massive toe in on the passenger's side that has been a pain. I suspect this will make matters worse
Old Mar 6, 2018 | 12:09 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Toe is easy, adjust the tie rod end.
Old Mar 8, 2018 | 08:39 AM
Urbanengineer's Avatar
Originally Posted by yosip1115
I tried it!!
That's pretty funny actually. Thanks for looking into it - cheap camber kit!
Old Jun 17, 2022 | 10:49 AM
NicSutter's Avatar
G35X
I also have an '05 G35x AWD, Bro. I just got aftermarket camber adjustable UCA's which I assume for actually for RWD models. Your insight is giving me hope! I'l also going to lower the car by one inch because I have coilovers as well. Thanks for this info!!!!
Freeman186
Sep 6, 2023 10:07 AM
Danielek
May 1, 2022 01:28 PM
boostelevator
Engine - Intake/Fuel
12
Jan 12, 2016 11:35 PM
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
