need help!!!!
Old Mar 8, 2010 | 02:42 AM
curby4's Avatar
need help!!!!
hey i was wondering what is the purpose of the yellow bolt that is in between 2 studs on the front rotors? the reason is because i bought wheels this weekend and that piece is in the way..i was wondering what is the best way to go about this problem?
Old Mar 8, 2010 | 03:42 AM
E-Ticket Ride's Avatar
That's to prevent the rear rim from being used on the front. You can remove it.
Old Mar 8, 2010 | 09:07 AM
tg1234's Avatar
^^What he says.
Old Mar 8, 2010 | 12:13 PM
curby4's Avatar
so if i grind it down nothing drastic will happen?
Old Mar 8, 2010 | 12:39 PM
Why would you grind it when it unscrews?
Old Mar 8, 2010 | 01:07 PM
kool_yaar's Avatar
^ exactly, take a philips head screw driver and screw it off without much force or if use a proper socket and take it off, its very easy with no use for grinding.
Old Mar 8, 2010 | 01:15 PM
nghiars's Avatar
^^^+ 1
Old Mar 8, 2010 | 02:43 PM
LightsOut's Avatar
SIETESG
Old Mar 10, 2010 | 10:07 AM
Q8y_drifter's Avatar
Lmao ^^
