Removed my front license plate holder and found...
Old Mar 29, 2010 | 01:29 PM
CaboWabo's Avatar
THIS!!
It looks like the previous owner might have pulled in too close to pole or something, causing the plate holder to just barely make an indentation into the bumper.
BALLZ!!! I was prepped to plug the holes, but now it looks like new bumper/paint or putting the front holder back on. We only run one plate in AZ, and I'm not a fan of those cheesy license plate inserts.
Oh well!
Attached Thumbnails Removed my front license plate holder and found...-0329001017.jpg
Old Mar 29, 2010 | 01:55 PM
AesonVirus's Avatar
Bummah'
Old Mar 29, 2010 | 02:12 PM
J2S2M's Avatar
I suggest puttin it baack on unless you want to get that repaired.. but that's gonna cost you a pretty penny. If you can afford it, fix it. If not, put the plate back on as a temp fix.
Old Mar 29, 2010 | 03:01 PM
Defratos's Avatar
You're Despicable
Damn that's a nasty surprise
Old Mar 29, 2010 | 04:18 PM
hybridamp's Avatar
ouch
Old Mar 29, 2010 | 04:27 PM
Locksmith's Avatar
Jus put it back on that looks wack.
Old Mar 29, 2010 | 04:38 PM
LightsOut's Avatar
SIETESG
try and roll or push it out.
Old Mar 29, 2010 | 04:43 PM
JIle342's Avatar
shouldn't be too hard to fix that
Old Mar 29, 2010 | 04:44 PM
CaboWabo's Avatar
Think so? I'll give it a shot and see what happens.
Old Mar 30, 2010 | 08:35 AM
johnnyzee's Avatar
^I've seen a guy with something like that on his rear bumper.
He heated the area up to soften it and pushed it out...looked pretty damn good.
Old Mar 30, 2010 | 11:56 AM
LightsOut's Avatar
SIETESG
it should work.
I once reversed my ex girl scion into another car...oops.
weeks later I got the end of a broom stick and pushed out the dent I made. Dent pushed out like a charm.
Old Mar 30, 2010 | 12:09 PM
GAU-8's Avatar
Body shop here in LV fixed mine on my rear bumper. Doesn't look like it ever had a problem. Easily fixed.
Old Mar 30, 2010 | 12:32 PM
Q8y_drifter's Avatar
that's very easily fixed. We have a shop here called Dent Xpress. They fix dent's (tiny and large) like nothing ever happened. I'm pretty sure you have something similar over there.
Old Mar 31, 2010 | 11:53 AM
LakeShore_Slate's Avatar
Google PDR in your area...Paintless Dent Repair. If all else fails.
Old Mar 31, 2010 | 11:57 AM
CaboWabo's Avatar
it should work.
Awesome guys, thanks. I was under the impression that on urethane (or the like) that you couldn't reshape it or worse, repaint it, without it being stripped bare. Anyway, I'm going to try pushing it out first, and if that doesn't work, call on some PDR. My boss had some dings taken out on his Denali (albeit metal panels) and it came out phenomenal.
