shudder over 80 miles
Old May 4, 2010 | 07:00 PM
firozu's Avatar
my steering wheel shudders at over 80 mph and stops at 90....dealer said i needd to balance my tires but im just trying to cover all my bases in case the dealership is wrong....which they are 90 percent of the time
Old May 4, 2010 | 08:03 PM
madmax2k1's Avatar
It's usually a tire balance issue and on the rare occasion a drive-shaft issue.
Ask your dealer to perform a road-force balance which is more accurate than traditional balancing.
Old May 4, 2010 | 09:53 PM
kool_yaar's Avatar
^ like they said it is 90% likely to be the a wrongly balanced wheel, then check the alignment if that doesnt fix the issue, then the steering rack (but in the latter 2 cases you would feel the "shudder" throughout and not at certain speeds i believe).
Old May 4, 2010 | 10:57 PM
bigc's Avatar
Wings Nation
tires
Old May 4, 2010 | 11:09 PM
sunny G-35 NYC's Avatar
could be because if wheel balance, irregular tire wear, alignment
Old May 5, 2010 | 11:17 AM
dohturdima's Avatar
If none of these things, could be a tie rod issue (had this happen in my Altima)
EDIT: just noticed that shrudder stops at 90 MPH - tie rod not likely then
Old May 5, 2010 | 11:48 AM
If it was your tie rod you would get Shudder or vibrations at any speeds.
Th611
Oct 27, 2015 03:48 PM
derres
Aug 28, 2015 03:27 PM
Gip
Aug 24, 2015 05:31 PM
linedr89
Aug 17, 2015 05:11 PM
Jroc2017
Aug 12, 2015 11:21 AM
